I didn't even know you need to install the package mlat-client on the RPi.
This is new i presume as it's not in the install script?
STEP-1: Update & install mlat-client
sudo apt-get update
sudo apt-get install mlat-client -y
sudo reboot
IMPORTANT NOTE:Above method to install mlat-client may fail. If this happens, then use method given in the following post:
https://www.airnavsystems.com/forum/index.php?topic=101771.msg407051#msg407051
STEP-2: Edit file /etc/rbfeeder.ini, and ADD lines shown in RED to enable mlatNote:
Use actual values in place of:
xx.xxxxxx (latitude)
yy.yyyyyy (longitude)
zzz (antenna height,
in meters, above sea level)
sudo nano /etc/rbfeeder.ini
Quote
[client]
network_mode=true
key=aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
sn=EXTRPI000nnn
lat=xx.xxxxxx
lon=yy.yyyyyy
alt=zzz
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
STEP-3: Restart rbfeeder
STEP-4: Check page: radarbox24.com/stations/EXTRPInnnnnn
(replace nnnnnn by your station number)
IF MLAT IS OK, it will be like attached screenshot.
Alternate to STEP-2 (all other steps remain same)
Instead of editing file /etc/rbfeeder.ini and adding lat, lon & alt manually, you can set these from RB24 web interface as shown below:
1. Go to following web page (replace xxxxxx by your station number)
radarbox24.com/stations/EXTRPIxxxxxx
2. Login to your account.
3. After login, on top left of web page, at the end of the line showing your city,
Edit will appear, as shown by red arrow in attached screenshot.
Click
Edit. This will open lat/lon setting box. Set your lat, lon & alt there.
4. Go to
STEP-3 (restart rbfeeder)
If you provide the exact position on the website, the position will be automatically placed in the configuration file ;)
(At least i don't remember putting my coordinates into that file)
Its new and has not been announced officially yet. The X-Range 2 and X-Range, maybe other receivers as well but I don't know, are getting new firmware installed for MLAT capability. Once they all have their firmware updated an email will be sent to all feeders asking them where necessary to update their Pi and/or to update their exact lat/lon to enable MLAT across the board
Quote from: abcd567 on March 27, 2019, 05:03:46 PM
(Used actual values in place of xxxxxxxxxxxx, xx.xxxxxx, yy.yyyyyy, zzz (antenna height in meters)
Antenna height from ground or sea level?
Quote from: ea2ip on March 27, 2019, 06:49:35 PM
Antenna Height Above Sea Level.
Sorry forgot to write in last post, will correct now.
First in neighborhood :-)
Not problem, working
We have liftoff, MLAT is working :)
Note that per default the MLAT results from the rbfeeder MLAT are not visible in the local dump1090 map.
Hopefully when the feature is stable the feeder will have an option to enable forwarding the results to the local dump1090.
(https://www.airnavsystems.com/forum/index.php?action=dlattach;topic=101771.0;attach=51661)
Here you see that map?
thanks
That's the dump1090-fa webinterface with the wikipedia map tiles.
The layers.js can be modified to accept different tiles:
https://github.com/wiedehopf/dev-webview/blob/master/layers.js
But as i said those MLAT results are currently not visible.
If you have a Raspberry Pi getting that map shouldn't be too complicated.
Do the radarbox and xrange offer beast or AVR data via TCP?
It's not too hard to run a dump1090-fa in net-only mode and display beast data from the web:
https://github.com/wiedehopf/combine1090#combine1090
If it is AVR and not beast you will have to modify the target port.
If trying to install mlat-client im getting the following:
Some packages could not be installed. That may mean that
You have requested an impossible situation or if you have the
Unstable distribution still use some required packages
have not been created or have not yet left Incoming.
The following information may help you to resolve the situation:
The following packages have unmet dependencies:
mlat-client: Depends on: python3 (> = 3.5 ~) but 3.4.2-2 should be installed
Depends on: python3.5: any is not installable
E: Problems can not be corrected, you have retained defective packages.
Ingo
Run
sudo apt-get update
sudo apt-get upgrade
If that doesn't help you might be on Raspbian Jessie and need an upgrade to Stretch.
Depending on which sd-card image you started from that isn't too hard.
Hello there,
I put up a new antenna on the roof today, and then went and enabled MLAT on my Pi according to the instructions above. However I suspect that something is wrong, seeing that the coverage has expanded all the way to GB (the antenna is no way that good). Also MLAT does not show on the station as your examples in this thread.
https://www.radarbox24.com/stations/EXTRPI001593
Will return to the field and do some error probing but ideas are welcome...
It looks like the feeder is updated correctly as you are showing the correct firmware version. However now edit your location with the exact lat/lon in decimal then save. Once that's done you should show MLAT active,
The spurious coverage shown over to the UK will wear off over the next week so I wouldn't bother with it
Quote from: neroon79 on April 19, 2019, 03:10:22 PM
Please post output of following command
cat /etc/os-release
Quote from: flygpagen on April 19, 2019, 05:50:55 PM
Something is indeed wrong, somehow the positions of aircraft above you are displayed way to the west.
I really have no clue how that could be happening.
Can you provide a screenshot of your local map, does it look like this as well?
Just in case you didn't already, do a reboot.
Quote from: wiedehopf on April 19, 2019, 03:54:20 PM
Run
sudo apt-get update
I just wanted you to know:
I waited as long as I could to do the Jessie -> Stretch migration due to the rule "never touch a running/working system". Anyway, migration worked without any severe impact or problem. After the migration the install mlat-client was of course working without any problem.
Thanks Ingo
Can you check if lat and lon are correct in /etc/rbfeeder.ini?
Fix them :)
(Press Ctrl-O and enter to save, then Ctrl-X to exit)
(That's about the only possibility i can imagine.)
I checked locally, putting in a position about 10 longitude to the west of your own position produces bogus positions.
After fixing the location you also need to stop rbfeeder or switch off the RPi for a couple of minutes, otherwise the feeder continues to be confused.
Using receiver local CPR is really a bad idea for feeding, just in case a developer is reading here :)
Stopping rbfeeder:
sudo systemctl stop rbfeeder
starting it again after a couple of minutes:
The station is at my airfield, I live appr. 25 kilometers away... Will install VNC server so that it will hopefully be easier to manage. :)
Anyway, I have updated the rbfeeder.ini with the following;
lat=56.131217 (was 56.131200)
long=13.879246 (was 13.879200)
That is the position I get when positioning using the radarbox webpage map localizer. Now powered Pi of, see if this helps. I have been trying to use the radarbox localization tool but it usually gives me this error;
We couldn't get your location!
Please ensure you have inserted decimal degrees or contact us at [email protected] to manually update
The rbfeeder.ini needs this:
lon=13.879246
long has an extra g in your version!
But the abbreviation for the config is lon not long.
(this could have resulted in the program using 0 as longitude/lon which looks exactly like your problem)
Well... I blush. Thank you for seeing this error! Corrected & restarted!
Quote from: flygpagen on April 20, 2019, 10:25:36 AM
Good that you put it in your post, otherwise i would have been out of luck.
Anyway long is a perfectly valid abbreviation, just not the one commonly used it seems :)
Your station looks better already!
Well done
Got it installed. Thanks. No MLAT synched as of right now but I don't know how much coverage RB24 has in Texas.
I think at this stage the issue may well be that the majority of users are not set up for MALT yet
Quote from: Runway 31 on May 22, 2019, 08:26:51 AM
....the majority of users are not set up for MALT yet
... because majority of users do NOT know that they can enable malat. :)
I have been waiting on a email going out to users to advise. A new firmware to enable for x-range units is due out by the weekend, maybe after it is out they will broadcast
Yeah, I found out only by accident, looking at my feed webpage, it was saying "MLAT not enabled" and had instructions how to enable it.
Now I am synced with 5 receivers.
For comparation, on the FlightAware side I am "synchronized with 185 nearby receivers".
Quote from: SoNic67 on June 02, 2019, 02:44:09 PM
Hi, What is your feeder "alias"?
Today I wrote latest Raspbian image (Buster) to microSD card and installed rbfeeder.
All went ok and the feeder is working fine.
However when I tried to install mlat-client by following command, it failed:
pi@raspberrypi:~ $ sudo apt-get install mlat-client
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
mlat-client : Depends: python3 (< 3.6) but 3.7.3-1 is to be installed
E: Unable to correct problems, you have held broken packages.
I solved this problem by building the mlat-client package from source code as follows:
## Installed required packages (dependencies and build tools)
sudo apt update -y
sudo apt-get install -y git curl build-essential debhelper python-dev python3-dev
## Downloaded source code
cd /home/pi/
## Built mlat-client's installation package
cd /home/pi/mlat-client
sudo dpkg-buildpackage -b -uc
## Above command took some time to build package
## After the package was built, installed it by following command
cd /home/pi/
ALTERNATE to building mlat-client from source code as above, you can now install pre-built package available at my Github site. Please see this post for details:
https://forum.radarbox24.com/index.php?topic=101771.msg433591#msg433591
I too have had the same problem however tried running the code as provided and now get the following error-
error: cannot access archive 'mlat-client_*.deb': no such file or directory.
Any ideas? thanks
Quote from: whome82 on July 02, 2019, 10:29:39 PM
Any ideas? thanks
Sorry, there was a mistake in the second last line.
It was wrongly written "cd /home/pi/mlat-client".
The correct command is "cd /home/pi/"
The last two commands should be like below. I have now corrected it in my original post also
cd /home/pi/
Thank you, Perfect now working with MLAT on my Pi also!
Great stuff
Thanks was able to get MLAT issue resolved for both my feeders. I had autostart_mlat set as true but that did not help, I had to put in the coordinates in the ini file for it to work.
That's correct, Pi's require the lat/lon to be set for MLAT
In my new installation with Buster, I faced the same problem and recreated "mlat-client_0.2.10_armhf.deb". After I ran dpkg -i, I copied the fa-mlat-client to /usr/bin and radarbox24 feeder picked it up and started MLAT. I then removed the packages build-essential debhelper python-dev python3-dev and the mlat-client folder.
But sudo apt-get update is again displaying the error:
The above packages have several dependencies which I did not want to keep in the system. I have kept git and curl though.
Its worth mentioning that mlat-client_0.2.10_armhf.deb package is also there under /home/pi/adsb-exchange and the sub folder adsb-exchange also contains another folder "mlat-client" but which may be a different version as judged by file size of fa-mlat-client:
1) /user/bin/fa-mlat-client * 2147bytes
2) /home/pi/adsb-exchange/mlat-client/fa-mlat-client * 2149 bytes
You need python3 for mlat.
Just install it with apt install.
I've tried this build for the MLAT client but still inactive. I'm running Buster Lite and dump1090-fa
Any suggestions of what else I could try?
(1) Have you added your latitude, longitude and altitude (lat, lon, alt) in settings?
Please see STEP-2 (or Alternate to STEP-2) in this post:
https://forum.radarbox24.com/index.php?topic=101771.msg389571#msg389571
(2) To make sure mlat-client is installed and working ok, post output of these two commands
apt-cache policy mlat-client
sudo systemctl status mlat-client
Yes, all the site details are input.
This is what I get from the two commands you requested:
pi@raspberrypi:~ $ apt-cache policy mlat-client
mlat-client:
Installed: 0.2.11
Candidate: 0.2.11
Version table:
*** 0.2.11 100
100 /var/lib/dpkg/status
pi@raspberrypi:~ $ sudo systemctl status mlat-client
● mlat-client.service - LSB: Multilateration client
Loaded: loaded (/etc/init.d/mlat-client; generated)
Active: active (exited) since Tue 2020-02-25 19:44:49 GMT; 3h 1min ago
Docs: man:systemd-sysv-generator(8)
Process: 320 ExecStart=/etc/init.d/mlat-client start (code=exited, status=0/SUCCESS)
Feb 25 19:44:48 raspberrypi systemd[1]: Starting LSB: Multilateration client...
Feb 25 19:44:49 raspberrypi mlat-client[320]: Not starting mlat-client daemon, disabled via /etc/default/mlat-client ... (warning).
Feb 25 19:44:49 raspberrypi systemd[1]: Started LSB: Multilateration client.
After inputting those two commands that you suggested, it appears to be working now
Have they triggered it into action?
Many thanks
Quote from: Nigelrich on February 25, 2020, 10:56:32 PM
Many thanks
When you go to following page, do you see "Mlat active (xx stations synced)", as shown in screenshot below.
http://www.radarbox24.com/stations/EXTRPIxxxxxx
(Replace xxxxxx by your station number)
Yes I do. I did exactly the same re-build on another Pi and didn't have any problems, which puzzled me why one didn't work and another did. Anyway they are sorted now.
Many thanks for your help
As an interim measure, I have built two mlat-client packages, one for Raspbian STRETCH and other for Raspbian BUSTER, and uploaded to my Github site.
These can be easily installed by following commands:
To install on RPi with Raspbian BUSTER:
## Download mlat-client package for BUSTER
wget https://github.com/abcd567a/mlat-client-package/releases/download/v1/mlat-client_0.2.11_BUSTER_armhf.deb
## Install downloaded package
sudo dpkg -i mlat-client_0.2.11_BUSTER_armhf.deb
To install on RPi with Raspbian STRETCH
## Download mlat-client package for STRETCH
wget https://github.com/abcd567a/mlat-client-package/releases/download/v1/mlat-client_0.2.11_STRETCH_armhf.deb
sudo dpkg -i mlat-client_0.2.11_STRETCH_armhf.deb
If you are not sure your Raspbian is Stretch or Buster, issue this command to find out
lsb_release -sc
Instructions here:
https://github.com/abcd567a/mlat-client-package/blob/master/README.md
Hi Everyone,
apologies in advance incase this has been asked several times before,
I have searched this forum but can't seem to find an answer
I have a feeder currently running piaware and I have just installed Radarbox
all in all the installation went well no errors YAY
however I don't seem to be getting any mlat results on the Radarbox site where as i am on the piware site..
I have seen some mention on the forum of installation of a mlat client for radar box, do i still need to do that even know i already have piaware installed ?
Thank you once again for your time and effort looking forward to your reply
I don't know anything regarding Pi's but I would think that the MLAT client is specific to each provider i.e Radarbox, Flightaware etc and each will need their own client as the data will not be shared between providers. Hopefully someone can advise if this is correct
For MLAT to work however you need to edit your location with your exact lat/lon and suggest that if you have not already done so to do this as a first step. Use Edit next to your location on the status grid top left of the MyStation screen
@ddolbel:
(A) To enable mlat, you have t do following TWO things:(1) Install mlat-client
(2) Enter your latitude, longitude and elevation above sea level.
(B) To see mlat results plane on dump1090-fa (SkyView) map:
Edit this line:
Original Line:#mlat_cmd=/usr/bin/python3.5 /usr/bin/mlat-client
After Editing:Note: Dont forget to remove # at start of the original line
For Raspbian Stretch:mlat_cmd=/usr/bin/python3.5 /usr/bin/mlat-client --results beast,connect,127.0.0.1:30104
For Raspbian Buster:mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client --results beast,connect,127.0.0.1:30104
lsb_release -sc
Contents of file /etc/rbfeeder.ini
Quote
[client]
network_mode=true
key=xxxxxxxxxxxxxxxxxxxxxxxxx
sn=EXTRPI00xxxx
lat=xx.xxxx
lon=yy.yyyy
alt=zzz
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
@abcd567
Thank you for the update....
ok just to reconfirm my piaware is working and mlat is being reported for piaware..
what i'm checking is that do i need to install another mlat-updater just for radarbox?
@ddolbel:
From user's point of view, enabling mlat on one site is enough, but enabling mlat on more than one site does not hurt. It however benefits the sites for which mlat is enabled
The FlightAware mlat:
(1) The mlat calculations are done at FlightAware servers.
(2) Used by flightaware on the map served by Flightaware server.
(3) Fed back to the feeder'Pi and by default displayed on SkyView map. User does mot have to make any configuration for this.
The RadarBox24 mlat:
(1) The mlat calculations are done a Radarbox24 servers.
(2) Used by flightaware on the map served by Radarbox server.
(3) Results are fed back to the feeder's Pi and can be displayed on SkyView or VRS. However unlike Flightaware mlat, this is not by default and user has to modify config as I have shown in my above post.
The FlightRadar24 mlat:
(1) The mlat calculations are done a FlightRadar24 servers.
(3) Results are NOT fed back to the feeder's Pi
@abcd567
thank you for your response
I have just tried to install the mlat-client however unable to locate the package
pi@piaware:~$ sudo apt-get install mlat-client
E: Unable to locate package mlat-client
Quote from: ddolbel on April 30, 2020, 08:55:48 PM
@abcd567
This means you missed to read the NOTE in my first post and did not go to link given in my first post.
Below is the quote from my first post, which contains the link. Please visit it and follow instructions there:
NOTE:
Above method to install mlat-client may fail for Raspbian Buster. If this happens, then use method given in the following post:
sorry i missed that, will give it a go
ps the piaware image is running jessie
i don't have python 3.5 installed only 3.4
i changed mlat in the rbfeeder.ini
mlat_cmd=/usr/bin/python3.4 /usr/bin/mlat-client --results beast,listen,30104
Jessie is too old. You will start facing lot of compatibality and upgrade problems soon.
Better format microSD card and write latest piaware image ver 3.8.1, which is Buster, then install rbfeeder and mlat-client.
I have ordered a new pi 4b will hang off till it arrives..
Thanks for your time and effort.
Hello Everybody,
Since re-installing my pi from jessie to buster, I also encounter problems with mlat-client.
I have installed dump1090-mutability and feed five sites, on most of them MLAT is working fine. I now installed the compiled version from @abcd567 using this hint: https://forum.radarbox24.com/index.php?topic=101771.msg433591#msg433591 (https://forum.radarbox24.com/index.php?topic=101771.msg433591#msg433591)
but mlat-client does not work.
using
sudo systemctl status mlat-client, the result is :
Active: active (exited) since Tue 2020-05-12 21:33:37 CEST; 1 day 1h ago
Process: 292 ExecStart=/etc/init.d/mlat-client start (code=exited, status=0/SUCCESS)
Mai 12 21:33:37 myPiADSB systemd[1]: Starting LSB: Multilateration client...
Mai 12 21:33:37 myPiADSB mlat-client[292]: Not starting mlat-client daemon, disabled via /etc/default/mlat-client ...
Mai 12 21:33:37 myPiADSB systemd[1]: Started LSB: Multilateration client.
What could be the reason therefore? The Radarbox Site says no MLAT active...
Thank you in advance.
There are two things required to be done:
(1) Install mlat-client, which you have done
(2) Set your latitude, longitude and antenna elevation. Did you do it? If not it can be done in any one of the two ways:
(a) Add these in file /etc/rbfeeder.ini
OR
(b) Go to your RB24 map on internet and add it there.
Both the above methods are described in STEP-2 of this post:
Thank you for the very quick answer.
I had written these lines to the rbfeeder.ini, but there was a mistyping: I wrote 1at=xx.xxxxxx instead of lat=xx.xxxxxx but I didn't recognize this difference in the terminal view.
Thank you very much, problem is solved, MLAT is working fine now :-)
1at instead of lat :(
Copy-paste from post (instead of typing) avoids typing mistakes.
Glad to know you could spot the typo, and now your system is up and running :)
Hello. I need some help with MLAT.
I use consol version dump1090 under win10 x64
I feed to RB24 from Data Sharer 1.20 win10 x64
I want feed MLAT
I feed to 12 serves from my VRS, and to FR and FA from ubuntu under hyper-V win10 x64 support/
Mlat work on FA, how feed Mlat to RB?
Mlat client in my ubuntu install and work by command:
mlat-client --input-type dump1090 --input-connect localhost:30005 --lat 52.35957 --lon 31.02599 --alt 126.1 --user UMGG --server feed.adsbexchange.com:31090 --no-udp --results beast,connect,localhost:30005
Maybe i can use second command mlat client.
Kirill EXTSHA193428 UMGG
Kirill
Try by clicking on Edit next to your location on the right of your MyStation map and enter your exact decimal lat/lot. This may not work using the data sharer software though and you may need to use the Pi method as detailed by abcd567
Like Adsbexchange, Radarbox24 also uses mlat-client, but control & configuration is through its feeder. The only version of RadarBox24 feeder which is mlat capable is the RPi (armv7) version. It wont work on Ubuntu x64.
As the source code is now available, you may try to build Ubuntu version of rbfeeder from source code. Please see this thread:
rbfeeder for x86_64 or i386 (https://forum.radarbox24.com/index.php?topic=102921.0)
Thank! I am ready to run on ubuntu, but I do not know Linux at all and do not know how to collect packages. Maybe you can collect for me?
Kirill:
Sorry, I tried, but could not succeed.
Some info needed to compile installation package, but the info is not made public by Radarbox24 software developers.
Flow Chart
(https://i.postimg.cc/QdpYV310/RB24-feeder-Flow-Chart.png)
Default Config (Without Mlat)
(https://i.postimg.cc/C1KcvntQ/RB24-Config-Default.png)
Config Mlat Enabled
(https://i.postimg.cc/bvpCtBR8/RB24-feeder-Config-MLAT-Enabled.png)
Hi guys,
I have followed the instructions to the letter for for RPi setup - EXTRPI010051
The lat/lon/alt are setup OK in rbfeeder.ini, along with the autostart_mlat=true.
The packages installed OK with no errors - I have restarted the RPi numerous times.
I have edited the site location via the map giving the same co-ordinates as listed in the rbfeeder.
I have stopped the service, waited until all my flights disappear, then restarted.
I just cannot seem to get MLAT working.
I have now run out of ideas and would welcome any input from the experts, please?
Thanks in advance,
Paul.
Edit - sorry - it's a Pi3 running Buster, also feeding FR24, FA, PF and PP.
Hi Paul
In addition to the RB feeder software did you install the MLAT client per Reply 1 of this thread
From a message by abcd on the previous page
(A) To enable mlat, you have to do following TWO things:
Thanks Alan - I have performed those steps - yes.
My rbfeeder.ini
[client]
network_mode=true
key=Removed
sn=EXTRPI010051
lat=53.1nnnnn
lon=-1.2nnnnn
alt=150
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
Output from sudo systemctl status mlat-client
(is the warning message important?)
Active: active (exited) since Sun 2021-01-03 14:28:32 GMT; 2 days ago
Process: 349 ExecStart=/etc/init.d/mlat-client start (code=exited, status=0/SUCCESS)
Jan 03 14:28:29 RPi3ADSB systemd[1]: Starting LSB: Multilateration client...
Jan 03 14:28:32 RPi3ADSB mlat-client[349]: Not starting mlat-client daemon, disabled via /etc/default/mlat-client ... (warning).
Jan 03 14:28:32 RPi3ADSB systemd[1]: Started LSB: Multilateration client.
Many thanks,
Paul.
Further investigation shows this:- (could there be a conflict with the other feeders, FR24, FA, PP and PF?)
pi@RPi3ADSB:/etc/default $ more mlat-client
# mlat-client configuration file
# This is a POSIX shell fragment.
# You can edit this file directly, or use
# "dpkg-reconfigure mlat-client"
# Start the client?
START_CLIENT="no"
# System user to run as.
RUN_AS_USER="mlat"
# User to log into the server as
SERVER_USER=""
# Logfile to log to
LOGFILE="/var/log/mlat-client.log"
# Input receiver type (dump1090, beast, radarcape_12mhz, radarcape_gps, sbs)
INPUT_TYPE="dump1090"
# Input host:port to connect to for Beast-format messages
INPUT_HOSTPORT="localhost:30005"
# Multilateration server host:port to provide data to
SERVER_HOSTPORT="mlat.mutability.co.uk:40147"
# Latitude of the receiver, in decimal degrees
LAT=""
# Longitude of the receiver, in decimal degrees
LON=""
# Altitude of the receiver, in metres
ALT=""
# List of result connections/listeners to establish.
# This should be a space-separated list of values suitable for passing to
# the --results option (see mlat-client --help for syntax)
RESULTS="basestation,listen,31003"
# Other arguments to pass to mlat-client
EXTRA_ARGS=""
Paul
Am out of my depth here and will leave it to abcd to come on and work his magic
Quote from: streety66 on January 05, 2021, 05:44:18 PM
[mlat]
autostart_mlat=true
The cause of failure is wrong version of python in above line of the file /etc/rbfeeder.ini
The python3.5 was for Raspbian Stretch.
The current version is Buster, which requires python3.7
To fix the problem:
Either change 3.5 to 3.7
OR BETTER
Comment out this line by placing a # at start of line
Placing a # at start of line will change line's color from white to blue. Please see screenshot below.After making and Saving changes, reboot Pisudo reboot
Quote from: Runway 31 on January 05, 2021, 06:49:05 PM
Paul
Take the plunge. Buy a RPi and start playing with it.
That is how everybody learns RPi and Linux.
When I purchased my first Pi about 5 years ago, my knowledge of Pi and Linux was ZERO.
Am thinking of it
Mr ABCD567, you Sir, are a true gent - I'm so grateful, thank you.
Now feeding MLAT.
Thanks also to Alan for his assistance.
May I ask what the mlat_cmd= line actually does and the implication of commenting it out? For now, I made the 3.5 to 3.7 change but if commenting the line is better, would like to understand why, please?
Cheers,
Paul.
The rbfeeder has this line built in, and provides it if this lines is commented out. This command starts the mlat-client
Commenting out is better from possible upgrade of rbfeeder in future which may require changing python3.7 to say python3.8 or 3.9 or 4. Commenting it out will force new version of rbfeeder to use correct version built into it.
Thanks once again - that makes sense when put like that and I have now commented it out and rebooted.
Much appreciated.
Paul.
On my pi mlat is active but just can't get it to sync with my station, have been working on this for days. Time to slit my wrist I think 😩
While you`re waiting for ABCD to help, try a nice single malt from Spey side.
Dave.
chipman, what do you mean sync with your station? If you mean why you are not seeing it showing as synced with other stations are you close enough to other MLAT stations. If you are showing as MLAT any MLAT active stations active within your coverage are automatically synced you dont do anything
What is your station number?
Also whatever, go with the single malt anyway :-))
Lol the single malt will go down a treat. I never realised what mlat no sync meant, I do now thanks. I must have another problem as not showing any aircraft. When using same areal and same position when I used my laptop with the old rb box I was getting 200+miles coverage. Now with raspi and radarbox micro nothing.
Station number EXTRPI020882
Chipman did you set up as per https://forum.radarbox24.com/index.php?topic=10201.0 and also set up the MLAT client per earlier in this thread
Looking at your MyStation link, you dont appeat to have MLAT set up
If you have a micro RB that can be used on your computer with the V6 software installed no issues,. You will also need to download and install the drivers for it http://www.airnavsystems.com/Download/ANRB/Drivers/microRadarbox-Drivers-20150411.exe Note you wont get MLAT with this method though
Use the same log in details you used with your original box
Thank you for that. As far as I could work out I did set up mlat as per instructions from threads on rb. I shall go to the thread you have posted and try again.
The issue is more than MLAT chipman as you are not feeding data either see https://www.radarbox.com/stations/EXTRPI020882. If you find the issue stopping you sending data the MLAT issue will probably be fixed as well
Hello,
I tried a few days but didn't managed to get MLAT sharing with Radarbox24.
Here is my rbfeeder.ini
[client]
network_mode=true
key=2256b30xxxxxxxxxxxxxxxxxxxxxx
sn=EXTRPI021224
lat=52.1xxxxxx
lon=10.2xxxxx
alt=117
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
external_host=192.168.0.12
[mlat]
autostart_mlat=true
[dump978]
Any suggestions how I could activate it?
Thanks for your help!
Olli
From an earlier post
To fix the problem:
OR BETTER
Hey Alan,
thanks for helping me.
I have already tried to command out it with the # (see my code above).
But changing 3.5 to 3.7 seems to working for me.....I´ll check this a few hours.
Thank you
olli
Olli
Per reply 74
Thank you Alan, i will change it back to 3.5 and comment it out and check the MLAT status.
I suggest you leave it at 3.7 and commented out per Reply 74
So following the best practice and adding a # in front of the line
do I need to move the --results to a new line ????
The line below is how my .ini file reads at present
mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client --results beast,listen,30104
i'm using a Airspy2 as my Rx
Mark
Not as far as I am aware but hopefully someone with more knowleadge can advise
Tried everything but it doesn't work quite well.
The MLAT status swich between:
-Active but not synched
-Active and synched with....(few Stations)
-dissapear completely
[client]
network_mode=true
sn=EXTRPI021224
lat=52.xxxx
lon=10.xxxx
alt=117
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
#mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client
[dump978]
Do i have to add something like "--results beast,listen,30104" ?
Thanks for alle the help!
Olli
It will only sync with stations if they are available to sync with and this will change as staton go on and offline
I have no idea regarding Listen
[email protected] may be able to advise further
Hopefully abcd will note the posts and come online later
Ollj
I see you have 38 stations synced at this time. I have no idea why the syncing comes and goes, maybe someone with more knowledge can anser
Quote from: derOlli on January 20, 2021, 03:43:51 PM
No, it is not necessary, and RB24 mlat works perfectly well even without it..
However if you are using dump1090-fa or dump1090-mutability, adding above to mlat_cmd will make RB24's mlat plane also to be displayed on map of dump1090-fa/dump1090-mutability
Thanks @abcd567,
bit confused as yes I am using dump1090-fa so is that a bad thing as i'm also feeding a few other feeders at the same time?
guess i # the line out in the .ini file i will see less aircraft on my map right?
Quote from: Amameric on January 20, 2021, 03:29:39 PM
Mark
Your current configuration is Good, keep it as it is (i.e. keep mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client --results beast,listen,30104)
Mlat setting will be same for generic dongles and AirSpy.
Thanks @abc567
you are a true gentleman with all your support you give us
I have the same problem. Looking through the rbfeeder status is appears that it's not receiving replies from RadarBox?
Jan 26 14:30:13 raspberrypi rbfeeder[4118]: Tue Jan 26 14:30:13 2021 Disconnecting from mlat1.rb24.com:40900: No data (not even keepalives) received for 60 seconds
Jan 26 14:30:13 raspberrypi rbfeeder[4118]: Tue Jan 26 14:30:13 2021 Connected to multilateration server at mlat1.rb24.com:40900, handshaking
The startup config looks okay though?
├─4118 /usr/bin/rbfeeder
└─4129 /usr/bin/python3.7 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 5x.xxxxxx --lon -2.xxxxxx --alt xx --user EXTRPIxxxxxx
any thoughts?
Quote from: AnthonyHunt on January 26, 2021, 02:40:13 PM
any thoughts?
Did you already asked the support? I only got a standard answer
That's ok don't worry, it will only sync when there is more than 3 stations nearby with MLAT as well.still have the same problem and no answer.
olli
I contacted the Development team who has advised me that following me raising the issue they have discovered a performance issue on some of the MLAT servers which they are now resolving. Should take 1 to 2 hours to resolve
This is good news
As I've also been seeing the same problem for months since I started feeding RB MLAT
Do we expect to see fairly constant synced stations from now ?
Quote from: Runway 31 on January 27, 2021, 04:09:39 PM
Oh Brilliant. I didn't get that far as I'd assumed that it must be a config issue? As when I was just feeding RB it was fine but as soon as I went FA/PA to RB it failed. was quite surprised when FR, OS & ADSX were working fine.
I'll keep my fingers crossed and keep my eyes on it during the evening.
I have no idea, like you I am only a user and I have no idea if it will resolve your specific issue
Funnily enough, my FA/PA MLAT is glitching tonight. Going up and down like RB. My status on ADSX seems to be fairly constant.
I know it needs at least three receivers, but RB (when its working) gets 90-100, FA/PA 230? That bit doesn't seem to be a problem!
Where are you located
Midlands in the UK.
You will be seeing a huge reduction in traffic there, I am seeing even less here in central Scotland
Tell me about it! Although quite enjoying sitting on the flight path of the vaccine run between Brize and Preswick!
Actually why I'd like to get MLAT up and running as a fair amount of low level military (one which squark and ones that don't) and Air Ambulance passes me.
RB MLAT hasn't stabilised yet, still disconnecting. FA/PA (320 stations last time i looked) doing it every hour or so.
Ollj, your post on the silhouette thread was removed, you may want to add it here
Not seeing any difference in my MLAT station reports, still going from no stations sync to 100's of synced stations!
There is an ongoing issue with RB at this time I am unable to get online and I have not been able to contact the developers due to this. There has been a server migration taking place with some stability issues now but work is ongoing to smooth out the issue. I dont know how this will be affecting your issue
Mine hasn't stabalised fully. Both FA/PA & RB, everytime I loose aircraft it drops connection and resyncs. RB has just come back up for me so I'll see whar happens.
Update : It's gone back to how it was previsouly, which is a shame as it had been fairly stable most of the day. Maybe they rolled back the changes they made yesterday?
I asked the support because of my MLAT problem and got a answer but I´m afraid to break my configuration:
sudo apt update -y
cd /home/pi/
cd /home/pi/
I don't see how that's any different to the version already installed? I checked the version I had and it was already the latest mutability build?
Happy to give it a go...
report back soon.
UPDATE: no change stayed sync'd for about 5m then dropped with the same error in the log. I havd at least 5 aircraft the whole time.
Until they resolve the issue you wont get a fix
Quote from: AnthonyHunt on January 27, 2021, 08:48:20 PM
Is that why I've been seeing & hearing a lot more A400M than usual flying past my house @10k feet these past few days?
-=Glyn=-
Nope the Covid flights arrive at Prestwick around 0200 as NPT037K/037F B733 and I believe they are from East Midlands not Brize
One of the reasons. A few C130 J's doing drops of supplies too. From what I hear, and could be wrong, they are doing "Hands off" combat type drops - using every opportunity for combat practice.
Quote from: Runway 31 on January 30, 2021, 09:17:35 AM
There's a bit more going on. Yes, vacinne itself is being delivered in "landed" flights. Depends on which of the two manufactoring sites. Brize is obviously next door to Oxford plant. Other supplies are arriving as my prvious post. Although I'm only informed by the RT that i hear.
Out of interest and totally OT... Pfizer has been arriving from Belgium to Liverpool on an Antonov AN-26 (circa 10pm?) followed by a Typhoon flypast. Seen it a few times now.
Ah the NPT flights are covid samples being delivered to the lighthouse lab for processing. I am not aware of any RAF A400 or C30J flights into Prestwick or Glasgow, none appearing on the movements anyway apart from the odd A400 doing overshoots training
Still no change with the MLAT YoYo'ing... There was an update to mlat-client yesterday but that didn't help anything. Guess the folks at AirNav are working on sorting their migration problem first.
They are trying to find a fix, no timescale given. Not linked to the migration issue which is now fixed
Maybe the problem is bigger than Radarbox? In the last week I've noticed that PiAware has started giving me MLAT errors
13% of UDP multilateration traffic sent by piaware is not reaching the FlightAware servers. This may indicate a network problem.
I know my network is good and the Pi up to date.
This evening I seem to have some stability in my MLAT servers. Also note that I had a period on downtime from RB which I suspect was there end not mine.
Yes RB had a server issue earlier
Re-Boot of the thread , ive been running the rb xrange for a good few days now and am at times syncing for several other mlat stations nicely (or so you'd think) !
So the issue is ..
On my station I'm not showing any mlat messaged received... ever
plus when i know i should be tracking/displaying something it is not showing on the map , yet clicking on a synced station maybe 3kms away it is displaying on theirs ..
And lastly , the synced stations /mlat line disappears altogether at times . Probably 50/50 as to whether it'll display or not , on one image you see it displayed
On the other its not ! only minutes apart
So .. is there something wrong somewhere ?
Still awaiting reply from support on this ..
Thanks in advance
PGANRB400732
I dont know if it has anything to do with it but your firmware version is from 2018. I see others for example Brinkley Arizona below you on the listing has a firmware from 2020 however i see that he has nothing in MLAT either
Thanks for that info Alan as usual a big help.
I'll whip out another support email for firmware update.
Unless you can fast forward the request?
Has to be worth a try at least, maybe its something else but a start at least for them to look into.
It wont help me passing it on. I would presume that it will be forwarded to a developer to look into it
I cant offer any assistance regarding MLAT other than advising to set your exact lat/lon so you will need to wait on support getting back
Still no real change in my MLAT yoyo'ing. I've just gotten use to it reseting continuously.
I have the same Issue with MLAT going into yoyo mode ( coming up and disappearing) I contacted support but they have not been helpful at all
only thing i have not done is re-installing the RBfeeder
Re-installing the feeder will not help, the issue is the way MLAT works on RB and there is nothing support can do about that. It need the developers to re-work how it is implemented
i contacted support twice and got the same answer
Basically MLAT will not hold then 5 mts and keeps going into a loop of disconnect and reconnect and vanish ( have to reboot PI to get it to work)
Thanks for your email.
There is an outage and we are investigating.
Please accept our sincere apologies for this matter.
Please do not hesitate to contact us if we can be of any further assistance.
My work rbfeeder.ini
[client]
network_mode=true
disable_log=0
key=*************************
sn=EXTRPI******
lat=**.******
lon=**.******
alt=***
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client --results beast,listen,30007
[dump978]
Mlat WORK!
Hello guys,
last couple of days I did tens, and maybe hundreds, of new installs of my Raspberry Pi 3B+ and the outcome is that I couldn't start MLAT service to Radarbox.
What do I do usually:
1. Install latest image of Raspbian OS Lite
2. Update it
3. Disable IPv6
4. Disable Power Management of my wlan0 because it's getting sleepy sometimes
5. Install Flightaware Piaware feeder
6. Install dump1090-fa
7. Enable Bias-T for my LNA on Piaware
8. Install Flightradar24 feeder
9. Install Radarbox feeder
10. Install MLAT client for Radarbox
11. Install Virtual Radar Server
12. Install Graphs1090
During last days I tried tons of combinations and different settings and everything else is working fine except MLAT service to Radarbox. All the other services start out of the box with minimal efforts and settings but Radarbox MLAT service didn't want to start, no matter what settings I put in the .ini file. I read a lot of forums, opinions and documentation but couldn't find solution for my problem. Finally I'm ready to think that this issue is server side problem.
Any help will be priceless, so please tell me what I'm doing wrong because today I wanted to throw away all my Cisco certificates, to punch with hammer my Raspberry and so on. Let's keep the Raspberry alive. Please, help me!
@bgaf
Please post output of following 2 commands:
(1) cat /etc/rbfeeder.ini
Replace feeder key by xxxxx when posting in forum.
(2) apt-cache policy mlat-client
Quote from: abcd567 on November 03, 2021, 09:57:25 PM
@bgaf
[client]
network_mode=true
disable_log=0
key=1234567890
sn=EXTRPIXXXXXX
lat=XX.423145
lon=XX.595999
alt=120
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
____________________________________________
mlat-client:
Installed: 0.2.11
Candidate: 0.2.11
Version table:
0.2.11 500
500 https://apt.rb24.com buster/main armhf Packages
*** 0.2.11 100
@bgaf
The mlat-client supplied by RB24 repository has a bug that if rb24feed is started by following command, it wont start mlat-client:
However if RPi is rebooted, mlat-client gets started.
Reboot RPi, wait for 15 minutes and check your RB24 station site to see if mlat started.
Most likely mlat will start by reboot. However if not, then possibly mlat-client install is broken. In this case, reinstall mlat-client by following command:
sudo apt-get install --reinstall mlat-client
sudo reboot
Wait for 15 minutes, then check your RB24 station site to see if mlat has started working.
Thank you for your advise. I already have done this a couple of times during all my installation attempts. Last night I installed your version of MLAT client on a fresh new install of the system. MLAT didn''t start properly too. The process itself is starting but it's doing nothing. On the stats page there is no indication that the MLAT service is working. I think there is some information flow error inside my Pi. Maybe some port is closed, some setting is wrong or something else. I will continue with my efforts to find out where the problem is and I hope to find it. If you have another ideas, please tell me. I will do everything to make it work.
After all my today's experiments I'm pretty sure the problem is on the server side. There is no reason for a working system to get disconnected from MLAT calculations without changes on my side. One day the label "MLAT Active (XX stations synced)" just disappeared. Last install of my Pi before the problem occur was maybe one year ago and for this one year the station was not working only when there were power outages or internet problems. Flightaware feeder, Flightaware MLAT, Flightradar24 feeder, Flightradar24 MLAT and RB24 feeder are working properly. Even my VirtualRadarServer is working without any efforts. Just RB24 MLAT service is driving me crazy. And the biggest problem is that if you setup everything like it's written in their manual, it won't work...Because I follow their official procedure and the result is --results make me beast,don't listen, any port.
Did you contact
[email protected]Alan
Quote from: Runway 31 on November 04, 2021, 12:47:05 PM
Did you contact [email protected]
Yes, their advices were read from forums. I can do it by myself without their intervention. Change that port number, try with this setting, try with that option...My little daughter can provide me better support. I'm glad they are not doctors. Finally they stopped answering to my questions. And this is my second time to contact them. I'll never do it again. They even don't care about receivers that they provide for free. I host such kind of XRange receiver and for them it's normal the range to be less then 100 nm. They don't see any problem with this receiver. So I stopped asking for help. Two days ago I sent them log file with some words play - there is a handshake with the server but actually it's just shaking hands. Too many talking but there's no communication. I asked why there's no connection after handshaking? And they just stopped answering to my e-mails. Anyway, I'll survive with or without their help.
@abcd567
Today I did again fresh install with your MLAT packages. Neither with them, nor with the original package MLAT service is running. The process itself is starting, I can see it in htop, but nothing else happens. I saw that the original package has before mentioned bug and it's not starting normally, so I can confirm that. And again my lovely questions - how can they provide officially packages that are not working? Don't they test them before publishing them? And I don't have answers. Even more - I don't have words...
P.S./ If you still want to investigate my case, feel free to ask for whatever information you need.
@bgaf
(1) The official mlat-client works OK if it is started by rebooting the RPi. It fails to start only if you try to start it by restarting rbfeedr by manual command.
(2) More than one program use mlat-client, each one uses its own installation of mlat-client. The top / htop will show all of them as follows:
- fa-mlat-client (user Flightaware Piaware)
- mlat-client (user Adsbexchange)
- mlat-client (user rbfeeder)
(3)Please post the output of following command (increase the width of SSH/PuTYY window to avoid cutting-off long lines).
This is the output:
pi@raspberrypi:~ $ sudo systemctl status rbfeeder
Active: active (running) since Thu 2021-11-04 19:13:08 EET; 8h ago
Main PID: 561 (rbfeeder)
Tasks: 11 (limit: 2059)
├─561 /usr/bin/rbfeeder
└─616 /usr/bin/python3.7 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 43.423145 --lon 24.59
Nov 05 03:26:42 raspberrypi rbfeeder[561]: Fri Nov 5 03:26:42 2021 Disconnecting from mlat1.rb24.com:40900: No data (not even keepalives) received for 60 seconds
Nov 05 03:26:42 raspberrypi rbfeeder[561]: Fri Nov 5 03:26:42 2021 Connected to multilateration server at mlat1.rb24.com:40900, handshaking
Nov 05 03:26:49 raspberrypi rbfeeder[561]: [2021-11-05 03:26:49] ******** Statistics updated every 30 seconds ********
Nov 05 03:26:49 raspberrypi rbfeeder[561]: [2021-11-05 03:26:49] Packets sent in the last 30 seconds: 290, Total packets sent since startup: 597607
Nov 05 03:26:49 raspberrypi rbfeeder[561]: [2021-11-05 03:26:49] Data sent: 19.7 MB
Nov 05 03:26:49 raspberrypi rbfeeder[561]: [2021-11-05 03:26:49] Data received: 14.2 KB
Nov 05 03:27:20 raspberrypi rbfeeder[561]: [2021-11-05 03:27:20] ******** Statistics updated every 30 seconds ********
Nov 05 03:27:20 raspberrypi rbfeeder[561]: [2021-11-05 03:27:20] Packets sent in the last 30 seconds: 259, Total packets sent since startup: 597866
Nov 05 03:27:20 raspberrypi rbfeeder[561]: [2021-11-05 03:27:20] Data sent: 19.7 MB
Nov 05 03:27:20 raspberrypi rbfeeder[561]: [2021-11-05 03:27:20] Data received: 14.2 KB
lines 1-19/19 (END)
└─616 /usr/bin/python3.7 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 43.xxxx --lon 24.xxx
Above is perfectly OK, no issues with rbfeeder or mlat-client
Above is the problem. No mlat data, i.e. either no mlat plane picked by your Antenna, OR not enough (minimum 4) receivers nearby to synchronize, resulting in disconnection-reconnection cycle.
However this may also be due to problem in RB24 Mlat Server
I think the problem is in the server because around me there are more then 15 MLAT receivers and my XRnage receiver is connected to them. My Pi, when it was working normally, was connected to the most of them too. Last time there was connected receiver from Hungary. The others are from Bulgaria, Romania, Greece and so on. Today I will pay attention and to my router. Maybe it's blocking some traffic because of it's security options.
Finally I got MLAT working. Up to now 15 stations has been synced to my receiver. The problem was in my router. It's security settings were blocking some traffic from my AP to the router. OpenWRT sometimes is more strict then it's needed. It was hard to believe but that's the truth.
My excuses to Radarbox. The software is working, despite the bugs it has.
@abcd567
Sir, thank you very much for paying attention to my problems. You've done tremendous efforts to support the community at all levels. Thank you once again.
Hello dear!
I have two receivers on Rpi connected to the Internet through different providers, the first one with a white dynamic IP, the second through a NAT provider, a gray dynamic IP.
MLAT is active, receivers are successfully transmitting data to FA, FR24 and two private servers.
I recently installed feeder Radarbox and MLAT from github. Before the change of the IP provider, MLAT data is transmitted, there is synchronization with other receivers,
After changing the IP, MLAT is not transmitted to the radarbox server. (FA, and two private servers will continue to operate) ADS-B planes on my receiver page show but no MLAT.
It turns out to restore connection, with the server by rebooting, or by the command: systemctl restart rbfeeder.
Tested many times. Always successful.
Client MLAT status: mlat-client.service - LSB: Multilateration client
Loaded: loaded (/etc/init.d/mlat-client; generated; vendor preset: enabled)
Active: active (exited) since Thu 2022-01-06 13:16:23 MSK; 5 days ago
Tasks: 0 (limit: 4915)
CGroup: /system.slice/mlat-client.service
Jan 06 13:16:23 Work-10-10-25-2 systemd[1]: Starting LSB: Multilateration client...
Jan 06 13:16:23 Work-10-10-25-2 mlat-client[308]: Not starting mlat-client daemon, disabled via /etc/default/mlat-client ... (warning).
Jan 06 13:16:23 Work-10-10-25-2 systemd[1]: Started LSB: Multilateration client.
What can I do to automate the process of connecting to MLAT Radarbox servers?
Sorry my English, this is a machine) Thanks for your reply!
I believe there is a bug in the MLAT client which requires you to either re-boot or to systemctl restart rbfeeder as you have noted. Hopefully this will be fixed before to long
Quote from: Runway 31 on February 16, 2022, 05:07:29 PM
Restarting by "sudo systemctl restart rbfeeder" does NOT solve make mlat to work. Only Rebooting RPi makes mlat to work.
I don't think RB24 software developers are interested in removing this bug, as it is lingering on from Buster time and now continuing in next generation OS Bullseye since almost an year.
To check if mlat is active, run status command:
If mlat-client is working OK, the output of status command should contain "/usr/bin/python3.9 /usr/bin/mlat-client". Please see below:
CGroup: /system.slice/rbfeeder.service ├─ 994 /usr/bin/rbfeeder └─1200 /usr/bin/python3.9 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 43.5>
If "/usr/bin/python3.9 /usr/bin/mlat-client" is missing, Reboot RPi and check again, it should appear after reboot.
Because RB24 has not solved this bug, instead of installing RB24 supplied mlat-client by command "sudo apt install mlat-client", I have built mlat-client from source code and installed on my RPi. I have uploaded these to my Github site, which also contains instructions as to how to install these for various OS (Buster, Buster-64bit, Bullseye, Bullseye-64bit)from where
https://github.com/abcd567a/mlat-client-package/blob/master/README.md (https://github.com/abcd567a/mlat-client-package/blob/master/README.md#mlat-client-packages-for-raspberry-pi)
NOTE:(1) After installing mlat-client, do not forget to restart rbfeeder by following command:
Thanks abcd, only a reboot will get it working again
Quote from: Runway 31 on February 17, 2022, 08:53:14 AM
The RB24 supplied mlat-client fails to restart automatically whenever rbfeeder is restarted by command "sudo systemctl restart rbfeeder". A reboot is required to restart it properly.
If RB24 supplied mlat-client is replaced by mlat-client from my Github site, it will always start when rbfeeder is restarted by command "sudo systemctl restart rbfeeder". There is no need to reboot to start it.
It is very easy to check if rbfeeder could start mlat-client.
Just issue command "sudo systemctl status rbfeeder" and in output, look for line containing "/usr/bin/python3.9 /usr/bin/mlat-client". If this line is missing, mlat client has not started.
Please see the relevant part of status command's output below.
├─ 997 /usr/bin/rbfeeder
└─1023 /usr/bin/python3.9 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 43.5>
Thanks abc it was the RB supplied feeder I was talking about. You info will be very handy for users
A
Quote from: abcd567 on February 17, 2022, 09:34:19 AM
abcd567 but if we put this at rbfeeder.ini the problem is solved or not?
[mlat]
autostart_mlat=true
Quote from: Aerotower on February 18, 2022, 06:46:42 PM
[mlat]
autostart_mlat=true
It did NOT solve for me.
The problem is NOT with rbfeeder or its configuration.
The bug is in RB24 supplied mlat-client package.
You can check yourself by changing config the way you suggested, save the changes, then:
(1) Give command "sudo systemctl restart rbfeeder", then check if MLAT is working.
(2) If not, Reboot Pi and check again.
In RB24 feeder's config file "/etc/rbfeeder.ini", under [mlat], the 2nd line (blue color) is by default commented out (i.e a # is placed at it's start). As per standard computer coding practice, the lines which are commented out (i.e. have # at their start) are ignored during execution. Therefore the 2nd mlat line is also ignored by rbfeeder.Quote
[mlat]
autostart_mlat=true
If the rbfeeder finds above line commented-out, it starts using it's in-built mlat command. From file "/etc/rbfeeder.ini" it uses lat, lon, alt, and user parameters.The rbfeeder's in-built mlat command is given below:Quote/usr/bin/python3.9 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 43.xxxxxx --lon -79.xxxxxx --alt 1xx --user EXTRPI000008 --results beast,connect,127.0.0.1:32004
The question is that why this commented-out line is there if it is not being used?The reason is simple. If anyone wants to overide defaults, he can un-comment (i.e. remove # from start of line) and modify this line to suite his requirements. When this line is un-commented, it is no more ignored by rbfeeder, and whatever setting is given by user over-rides the in-built default setting.If you see the default in-built line, it shows that mlat-results are fedback to RPi on port 32004: --results beast,connect,127.0.0.1:32004 Example 1:If someone wants mlat-results feedback to go to port 30104 (to display RB24 mlat planes on map of dump1090-fa or dump1090-mutability), then he has to do this in file /etc/rbfeeder.ini:(1) Scroll down to this lineQuote#mlat_cmd=/usr/bin/python3.9 /usr/bin/mlat-client
(2) Remove # from its start (line's color will change from blue to white)
(3) Add " --results beast,connect,127.0.0.1:30104 " to this line.After above 2 changes, the line will become like this:Quotemlat_cmd=/usr/bin/python3.9 /usr/bin/mlat-client --results beast,connect,127.0.0.1:30104
Example 2:If someone wants mlat-results feedback to say port 30007 to VRS on his Windows computer at 192.168.0.21, then he has to do this in file /etc/rbfeeder.ini:(1) Scroll down to this lineQuote#mlat_cmd=/usr/bin/python3.9 /usr/bin/mlat-client
(2) Remove # from its start (line's color will change from blue to white)(3) Add " --results beast,connect,192.168.0.21:30007 " to this line.After above 2 changes, the line will become like this:Quotemlat_cmd=/usr/bin/python3.9 /usr/bin/mlat-client --results beast,connect,192.168.0.21:30007
