AirNav Radar => AirNav Radar Discussion => Topic started by: gcopter1 on January 07, 2021, 03:11:33 AM
Title: Aircraft Selected at ANRB launch/Settings Retention
Post by: gcopter1 on January 07, 2021, 03:11:33 AM
When I launch the software, I automatically get an aircraft selected.
Why is this?
Where should I look to disable this?
While on the subject, there doesn't seem to be a way to retain advanced filters.
In my case, whenever I start ANRB, I'd like to filter out flights flying above 4,000 feet, to avoid screen clutter.
Yet, whenever I re-launch ANRB, the program seems to forget this setting, even after clicking on Map-Open/Save-Save As.
Title: Re: Aircraft Selected at ANRB launch/Settings Retention
Post by: Runway 31 on January 07, 2021, 09:51:33 AM
The top aircraft on the list is always selected look at the top left of the grid you will see a red box, there is no way of removing this as far as i am aware
When you close down all settings made during that session should be retained.  You require to close down using File/Exit, doing so maintains all settings, do not use the red cross top right of the screen to close down as everything is lost including logs from that session
Post by: gcopter1 on January 11, 2021, 07:52:09 PM
Sorry for the late response, thanks for your reply.
