AirNav Radar => AirNav Radar Discussion => Topic started by: Turbo on January 30, 2021, 01:34:30 PM
Title: Range Rings
Post by: Turbo on January 30, 2021, 01:34:30 PM
Is there a way of not havng them i find them annoying on my XRange 2  also how do i know what the distance from my location is on aircraft thanks..
Regards Lino.
Title: Re: Range Rings
Post by: Runway 31 on January 30, 2021, 01:40:41 PM
As far as I am aware there is no way of removing them.  Regarding the distance of aircraft from your location the range rings can give you an idea of the distance
Have you considered connecting your xrange to the Airnav V6 software as that gives the exact distance
Post by: Turbo on January 30, 2021, 02:10:53 PM
How do i get that software also usually i have an idea by looking at my other adsb receivers...
Lino..
Post by: Runway 31 on January 30, 2021, 02:16:31 PM
Lino
You can download it from here http://www.airnavsystems.com/download/ANRB/ANRB60003Setup.exe
Drivers here http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
Read here to give you an idea of it https://www.radarbox.com/legacy-software possibly similar to the Kinetic software you use
Post by: Turbo on January 30, 2021, 02:19:53 PM
Thanks will have a go at it..
Lino.
Post by: Runway 31 on January 30, 2021, 02:23:16 PM
It connects through your home network and it set up through File/Preferences where you set up your IP etc
Post by: Turbo on February 01, 2021, 12:53:59 PM
Hi Alan those links i cannot acess.
Lino.
Post by: Runway 31 on February 01, 2021, 01:46:04 PM
The links dont appear to be working as expected, use Open Link in New Window and they download OK.  I will advise Airnav to correct the link workings
https://www.radarbox.com/legacy-software is working as expected and if you scroil down the page you will see the links
Post by: Turbo on February 01, 2021, 09:03:39 PM
That link works thanks do i download all of them.
Limo.
Post by: Runway 31 on February 01, 2021, 09:19:11 PM
No just the ones on my previous email
Post by: GlynH on February 02, 2021, 08:16:43 AM
Also you will need to go to File/Preferences/Radarbox/ and at the bottom of the left hand side where it says RadarBox New Firmware (which is a little misleading IMHO) IP Address which will be the IP Address of your XRange and also port which should default to 32088
Just bear in mind that when using v6.02.003 you will lose the ability to click on an aircraft on the radar screen and have it highlighted in MyFlights!
It would appear that AirNav have no interest in fixing this fundamental issue...<sigh>
Thanks & kind regards,
-=Glyn=-
Post by: Runway 31 on February 02, 2021, 10:23:30 AM
He didnt have the ability in the first place so no loss.  Thankfully I dont have the issue not a having a Pi or an xrange just a plain old Windows computer so can stay with 6.00.02 .  Sometimes its a blessing being behind with advances!!
Post by: EK01 on February 02, 2021, 01:20:56 PM
It also works with my BBC B computer !
