AirNav Radar => AirNav Radar Discussion => Topic started by: Auka on February 09, 2021, 06:33:22 PM
Title: Station offline after reinstall
Post by: Auka on February 09, 2021, 06:33:22 PM
Hello everybody
I'm a feeder with station https://www.radarbox.com/stations/EXTRPI008619  but since today, my SD died :(  I feed for other feeders (FR24, flightaware, planefinder,...) too and the 31 december, i had a power issue, since Flightaware didn't work anymore. The raspberry had some difficulties to boot again but it started again
Today after an update, SD died :(
I reinstall all my feeder but radarbox doesn't want to be online
when I do this command sudo systemctl status rbfeeder
I have this result
   Active: failed (Result: exit-code) since Tue 2021-02-09 18:26:28 GMT; 35s ago
  Process: 12511 ExecStart=/usr/bin/rbfeeder (code=exited, status=1/FAILURE)
Main PID: 12511 (code=exited, status=1/FAILURE)
Feb 09 18:26:28 raspberrypi systemd[1]: rbfeeder.service: Service RestartSec=100ms expired, scheduling res
Feb 09 18:26:28 raspberrypi systemd[1]: rbfeeder.service: Scheduled restart job, restart counter is at 5.
Feb 09 18:26:28 raspberrypi systemd[1]: Stopped RBFeeder Service.
Feb 09 18:26:28 raspberrypi systemd[1]: rbfeeder.service: Start request repeated too quickly.
Feb 09 18:26:28 raspberrypi systemd[1]: rbfeeder.service: Failed with result 'exit-code'.
Feb 09 18:26:28 raspberrypi systemd[1]: Failed to start RBFeeder Service.
what could be the issue ?  I followed the same step than the first time I installed it
thx for your assistance :)
Title: Re: Station offline after reinstall
Post by: Auka on February 10, 2021, 06:40:42 AM
Hi Everybody
Just find the solution. it's was just a f£*%*%* point at the wrong place in the config file
It's back online now :)
Post by: Runway 31 on February 10, 2021, 08:42:06 AM
Well done in finding the problem
