hi there can someone help me please i have a radarbox metal type and i feed into the system using a flight stick all ok but i pluged in the metal radar box and all was ok but i had to reboot the system and all i have is a green light after that i tried it on different usb cable ports ect no joy i even had a second one and its the same. but the flight stick is still ok any ideas please
The drivers are different, you will need to install the drivers for the box from here
https://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
Note it is a zipped file, give it time for the command box to disappear when you run it
