I've just reloaded my Airnav Box 3D Will more windows open if I sign up for membership
What do you mean by more windows?
I'm clicking on various boxes along the toolbar and not getting any response what i need to know is if i pay will those boxes become active
There is no need for payment for anything to open up. Can you give an example of which boxes you refer to
Hi Alan thanks for your time I am new to this I was given the Radar Box3D and advised not to use the disc but download the lasted version from the site 6.02.003 hardware connect ok Real time network ok Network refresh data ok select tutorial never loads all the icons from set through to home page takes ages to load my system is Win 10 64bit i5 660 3.33 mhz dual core Nvidia GTX460 8Gig ram 256 Sata hard drive Regards Roy
Hi Roy
I dont know if the tutorial has ever worked
I dont understand what you mean by loading all the icons. At the top of the page above the grid and the map there are 3 rows
1st line File, Filters, Map etc
2nd line Symbols
3rd line Tour, Airline, Origin etc
Is it line 2 you are meaning, see attached screen shot If it is, hover the cursor over the symbol to see what they are for. i.e clicking the home button will center your home location on the map
Also did you install to program files or the recomended c:/Airnav
Waiting to hear further from you
Thank you for your support I have reloaded into c:/Airnav much better response how do i make the map screen smaller so i can see all the flight details in the right hand pane
Roy
Put your cursor over the edge between the map and the grid and it will change shape with two lines between a left and right arrow, you can then drag to the left or right to get the size you want
Any other queries just ask
