Hello, I have just started to transmit data to the radarbox servers on 2021-10-25, but the MLAT does not work, my station number is the following: EXTRPI012580
And this is my rbfeeder.ini file:
[client]
network_mode=false
disable_log=0
key=8db1d720531bd81d4daa8b7bc90d9aa7
sn=EXTRPI012580
lat=21.934401
lon=-99.993942
alt=995
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
I have already make all the process of installing Mlat with the following:
sudo apt-get install mlat-client -y
and still nothing.
My equipment is a Raspberry 4 with a RADARBOX ADS-B flightstick and a AirNav Systems ADS-B Outdoor antenna optimized for 1090 MHz
What can I do to make the MLAT work?
Thanks in advance for your kind response.
What version of Linux are you using?
You will find plenty of info on this thread https://forum.radarbox24.com/index.php?topic=101771.0
Thanks very much. I follow the step indicated and now MLAT is working.
Best regards
José Antonio
Great news
