Any idea how to install rbfeeder on the latest Raspbian OS Bullseye image?
(https://i.postimg.cc/SNRGJ8PM/Screenshot-2021-11-13-001701.png)
[EDIT 26-01-2022] This workaround is now NOT required as RB24 has added rbfeeder package to their installation script on 24-01-2022.
To install rbfeeder on the latest Raspbian OS Bullseye image, follow this procedure:
(1) Issue following command to download file inst_rbfeeder.sh
wget http://apt.rb24.com/inst_rbfeeder.sh
(2) Open downloaded file for editing by following command
sudo nano inst_rbfeeder.sh
(3) Scroll down the file to the line which starts with:
VERS=
(4) Comment out this line by placing # at its start like below
#VERS=
(5) Below this line type following:
VERS=buster
Please see screenshot below:
(https://i.postimg.cc/gkHvQ2rv/RB24-on-Bullseye.png)
(6) Save file (Ctrl +o) and Close (Ctrl+x)
(7) Issue following command to start installation
sudo bash inst_rbfeeder.sh
Thank you for the instructions. What about the MLAT client?
Quote from: bgaf on November 14, 2021, 01:18:41 PM
First try to install mlat-client by following ccommand:
sudo apt-get install mlat-client
Most likely by above command it will get installed and work ok. In case it fails to install or fails to work, build mlat-client from source code.
Thank you once again!
I tried to install mlat-client on Bullseye, got following:
(1) AFTER installing rbfeeder, gave following command but it failed to install mlat-client
(2) Tried to build mlat-client from source-code, using method in following post, but it also failed
https://forum.radarbox24.com/index.php?topic=101771.msg407051#msg407051
(3) Modified the procedure to suite Bullseye by adding command "sudo apt-get install -y dh-python" just before the command "sudo dpkg-buildpackage -b -uc". This succeeded .
The finished procedure for building mlat-client from source-code on BULLSEYE is as follows:
PROCEDURE FOR BUILDING & INSTALLING MLAT-CLIENT ON BULLSEYE
## Installed required packages (dependencies and build tools)
sudo apt update -y
sudo apt-get install -y git curl build-essential debhelper python-dev python3-dev
## Downloaded source code
cd /home/pi/
## Built mlat-client's installation package
cd /home/pi/mlat-client
## Above command took some time to build package. After the package was built, installed it by following command
cd /home/pi/
Maybe it's better to wait some more time for the companies to build their packages for Bullseye...
Quote from: bgaf on November 16, 2021, 11:17:39 AM
Yes, you are right. At this stage there is no advantage of switching from Buster to Bullseye as Buster is still fully supported.
However just for the sake of experimenting, couple of days ago I installed Raspberry Pi OS Bullseye, and on it successfully installed all feeders.
(1) dump1090-fa and
piaware: The Buster packages from Flightaware fail to install on Bullseye. I built these on Bullseye using automated install scripts I have posted on Github.
https://github.com/abcd567a/piaware-ubuntu20-amd64/blob/master/README.md(2a) Radarbox24 feeder: The Bullseye package is not yet available. Installed available Buster package by method I have posted above. In this method, I have modified the installation script to trick it to think the OS is Buster, and it installs the available Buster package
(2b) mlat-client: The available Buster package fails to install on Bullseye. I built it on Bullseye from source code using method posted above.
(3) Flightradar24 feeder: Installed Buster package on Bullseye by following command
sudo bash -c "$(wget -O - https://repo-feed.flightradar24.com/install_fr24_rpi.sh)"
(4) Planefinder feeder: Installed Buster package on Bullseye by following commands
wget http://client.planefinder.net/pfclient_5.0.161_armhf.deb
sudo dpkg -i pfclient_5.0.161_armhf.deb
(5) Adsbexchange: Installed on Bullseye by following commands
wget -O /tmp/axfeed.sh https://adsbexchange.com/feed.sh
sudo bash /tmp/axfeed.sh
(6) Graphs: Installed on Bullseye by following command
sudo bash -c "$(wget -q -O - https://raw.githubusercontent.com/wiedehopf/graphs1090/master/install.sh)"
Did you mean it like you posted it or did you mean (5) Below this line type following:
VERS=bullseye
Quote from: abcd567 on November 14, 2021, 06:35:45 AM
VERS=
#VERS=
VERS=buster
Quote from: cbdagency on January 06, 2022, 05:24:18 PM
VERS=bullseye
I meant exactly what I wrote in my post i.e. following:
VERS=buster
The reason is that RB24 has not (yet) released their feeder for Bullseye. When install script detects OS version is bullseye, it cannot find rbfeeder for it and fails and exits with complaint "don't know how to install for ".
By adding line VERS=buster, the install script is cheated to think OS is buster, and installs the available package for buster. Luckily the package for buster works on bullseye also, so this cheat works. :)
RB24 have now added bullseye repository and rbfeeder's bullseye package is available now. Now there is no need for any workaround. Just run the normal installation command, and it will install it.
Quote from: abcd567 on January 25, 2022, 10:16:46 PM
Do we know how to get the mlat client working on Bullseye? I have tried just about all commands and am unable to get to a screen where I enter my lon, lat etc to set it up
Quote from: teesvalley spotter on January 26, 2022, 02:52:58 PM
@teesvalley spotter: Please scroll down to end of this post and see NOTE 2 to get answer to your question.
@all-other-users:Although RB24 have yesterday added rbfeeder for Bullseye to their repository and install-script, but unfortunately missed adding mlat-client package to their Bullseye repository.
Hopefully they will add it soon, and then you can simply install it by following command
sudo apt install mlat-client
Currently the above command gives following output:
E: Unable to locate package mlat-client
You have 3 options:
OPTION-1: Wait till RB24 adds mlat-client to their Bullseye repository
OPTION-2: Build mlat-client on your RPi from source-code - This requires installation of many building-tool packages on your RPi.
OPTION-3: Install it from my Github site. This is fast & does not require installing any building-tool packages on your RPi. Please go to page linked below and use following option:
(1) Package for Raspi OS BULLSEYE (32-bit)https://github.com/abcd567a/mlat-client-package/blob/master/README.md (https://github.com/abcd567a/mlat-client-package/blob/master/README.md#mlat-client-packages-for-raspberry-pi)
NOTE:(1) After installing mlat-client, do not forget to restart rbfeeder by following command:
(2) You have to set your receiver's Latitude, longitude and altitude (above sea level, in meters) in file /etc/rbfeeder.ini (please see screenshot below). Mlat wont work without setting these parameters.
sudo nano /etc/rbfeeder.ini
Quote from: abcd567 on January 26, 2022, 04:50:51 PM
@all-other-users:
You have 3 options:
NOTE:
Hi. I have followed your code but don't seem to get far. I get to this, at which point it stops
Quote from: teesvalley spotter on January 27, 2022, 07:32:39 PM
(1) Your screenshot shows that mlat-client has been installed successfuly, and installation process has stopped at right point.
Now follow NOTE (2) of my "How-to" post, (i.e. edit file /etc/rbfeeder.ini and add your latitude, longitude and altitude, then save file, then restart rbfeeder (or reboor Pi).
(2) Please do NOT quote my entire and very long "How-to" post when you ask sonething. This makes it hard for others to brows the thread.
Quote from: abcd567 on January 27, 2022, 08:44:48 PM
I have edited the relevant sections in sudo nano /etc/rbfeeder.ini but it just says MLAT active (No stations synced) I have rebooted the pi
Quote from: teesvalley spotter on January 28, 2022, 12:22:15 PM
Please post output of following command:
Quote from: abcd567 link=topic=105631.msg513631#msg513631
code]
[/code]
Hi. That returns this
rbfeeder.service - RBFeeder Service
Active: active (running) since Thu 2022-01-27 19:28:42 UTC; 1 day 14h ago
Main PID: 12619 (rbfeeder)
Tasks: 10 (limit: 2059)
CPU: 16min 17.857s
├─12619 /usr/bin/rbfeeder
└─12629 /usr/bin/python3.9 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 54.[REMOVED] --lon -1.[REMOVED] --alt 61 --user EXTRPI[REMOVED] --results beast,connect,127.0.>
Jan 29 10:03:53 piaware rbfeeder[12619]: [2022-01-29 10:03:53] ******** Statistics updated every 60 seconds ********
Jan 29 10:03:53 piaware rbfeeder[12619]: [2022-01-29 10:03:53] Packets sent in the last 60 seconds: 1, Total packets sent since startup: 86826
Jan 29 10:03:53 piaware rbfeeder[12619]: [2022-01-29 10:03:53] Data sent: 2.5 MB
Jan 29 10:03:53 piaware rbfeeder[12619]: [2022-01-29 10:03:53] Data received: 93 B
Jan 29 10:04:26 piaware rbfeeder[12619]: failed to rename /dev/shm//rbfeeder_history_66.json.HQcP6o to /dev/shm//rbfeeder_history_66.json: Operation not permitted (122 more error messages suppressed)
Jan 29 10:04:54 piaware rbfeeder[12619]: [2022-01-29 10:04:54] ******** Statistics updated every 60 seconds ********
Jan 29 10:04:54 piaware rbfeeder[12619]: [2022-01-29 10:04:54] Packets sent in the last 60 seconds: 2, Total packets sent since startup: 86828
Jan 29 10:04:54 piaware rbfeeder[12619]: [2022-01-29 10:04:54] Data sent: 2.5 MB
Jan 29 10:04:54 piaware rbfeeder[12619]: [2022-01-29 10:04:54] Data received: 93 B
Jan 29 10:05:26 piaware rbfeeder[12619]: failed to rename /dev/shm//rbfeeder_history_68.json.Odwozq to /dev/shm//rbfeeder_history_68.json: Operation not permitted (122 more error messages suppressed)
@teesvalley spotter
You have two wrong entries in your file rbfeeder.ini
Please see green arrows in screenshot of my file rbfeeder.ini attached below.
To correct these errors, plase do this:
(1) Open file rbfeeder.ini for editing
(2) In file opened, under [client]
change
network_mode=false
to
network_mode=true
(3) In file opened, under [network]
change
external_host=192.168.xx.xx
to
external_host=127.0.0.1
(4) Save file (Ctrl+O) and Close (Ctrl+x)
(5) Restart rbfeeder
(6) Check status
Thanks for your help, the MLAT client is now working and syncing
Amazing job gentleman.. Same problem that guys from above, Support from Radarbox24 useless... You guys here helped a lot... seems like RB script from webpage is for buster, not Bullseye.
Now I´m online again (WORKED ONLY FOPR 5 MINUTES)
After 5 minutes, stopped working... Any clue about this ? I have working FR24, Planefinder, Flightaware perfectly.
@raspberrypi:~ $ sudo rbfeeder --status
[2022-02-09 15:10:39] Starting RBFeeder Version 0.4.3 (build 20210909231001)
[2022-02-09 15:10:39] Using configuration file: /etc/rbfeeder.ini
[2022-02-09 15:10:39] Network-mode enabled.
[2022-02-09 15:10:39] Remote host to fetch data: 127.0.0.1
[2022-02-09 15:10:39] Remote port: 30005
[2022-02-09 15:10:39] Remote protocol: RAW
Error opening the listening port 32458 (Raw TCP output): bind: Address already in use
less /etc/rbfeeder.ini
disable_log=0
key=xxxxxxxxxxxxxx
sn=EXTRPI0xxxxx
lat=xxxx
lon=xxxx
alt=28
[network]
mode=raw
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=false
less /var/log/rbfeeder.log
[2022-02-09 15:08:22] Using configuration file: /etc/rbfeeder.ini
[2022-02-09 15:08:22] Network-mode enabled.
[2022-02-09 15:08:22] Remote host to fetch data: 127.0.0.1
[2022-02-09 15:08:22] Remote port: 30005
[2022-02-09 15:08:22] Remote protocol: RAW
[2022-02-09 15:08:22] Starting RBFeeder Version 0.4.3 (build 20210909231001)
[2022-02-09 15:09:19] Starting RBFeeder Version 0.4.3 (build 20210909231001)
[2022-02-09 15:09:19] Using configuration file: /etc/rbfeeder.ini
[2022-02-09 15:09:19] Network-mode enabled.
[2022-02-09 15:09:19] Remote host to fetch data: 127.0.0.1
[2022-02-09 15:09:19] Remote port: 30005
[2022-02-09 15:09:19] Remote protocol: RAW
Above, you have logs and ini to see my config. How to know if MLAT client is working for RB24? Is working fine with FR24 and Flightaware...
Help Help.--.
I know next to nothing regarding Linux but while waiting on abc123 I did note the following error
[network]
mode=raw
external_port=30005
Should be mode=beast
Quote from: Runway 31 on February 09, 2022, 06:37:52 PM
[network]
mode=raw
external_port=30005
Alan, thank you for the observation, but that was suggested by Support from RB24. Annoying...
Lets wait for the Wizard of ADS-B
Quote from: Av8tor_from_Argentina on February 09, 2022, 05:50:00 PM
You are using wrong command (
sudo rbfeeder --status) to check status. This started 2nd copy of rbfeeder, while 1st copy started by system was already running and using the ports. This resulted in Error message and failure.
Use following command to check status
NOTE: (1) First in file /etc/rbfeeder.ini, change the error mode=raw to mode=beast
(2) Next save file
(3) Next Reboot RPi
(4) Now issue following command:
[network]
mode=raw
external_port=30005
As already pointed out by Alan, mode=raw is wrong. It should be mode=beast.
Hi abcd567, is your Bake a Pi thread the best way to load a Pi, or with the updates is there a better script please?
Thanks, Dave.
Quote from: anorak on February 16, 2022, 04:13:11 PM
Thanks, Dave.
Hi Dave
I have not looked at my "Bake A Pi" howto for a long time. It is 2017 howto, and many changes have taken place during these 5 years. Obviously many procedures given in it most likely have become outdated.
Ok, this weekend (or may be next weekend) I will review it and update it. It may take more than one weekend.
abcd
Don`t worry how long it takes, if any one can, you can.
Your efforts are always appreciated, Dave.
