i installed both 1090 and 978 according to radarboxs directions changed 978 dongle as per directions but im still not getting the UAT data
You have not given very much detail on what you have installed
However see this thread and links contained https://forum.radarbox24.com/index.php?topic=105891.0 and se if these help
ive only installed the 1090 and 978 dongles totally fresh raspberry ive only installed the radarboxs software so no other adbs i changed the serial on the 978 just as the instructions had stated changed the 978 port and still no luck
Are you getting 1090 OK and can you show your ini file with your key details blocked out
i wonder if its the dongle i just plugged the green onr in lost all 1090 plugged my original rtl back in and 1090 works just fine
Cant really see anything wrong in your ini file althought I would suggest that you enable MLAT by changing false to true
The issue may be something to do with the sticks, I presume you renumbered them 0 and one etc
im gonna try i happen to have 2 generic rtl just laying around
I presume you have the red Airnav UAT 978 stick
its the 978 station set radarbox sent out for free
ok thanks
so it looks like that setup just picked up 1 packet of uat
That a start and shows that it is working, just need to get some for UAT flights around you
Whats your station?
EXTRPI016198
i have both radarbox dongles plugged in with a different power supply seems to be picking up uta now
Yes seems to be working ok, welcome and thanks for feeding
