AirNav Radar => AirNav Radar Discussion => Topic started by: CountryEd on May 06, 2022, 02:51:24 PM
Title: Trying to obtain ACARSD for RB
Post by: CountryEd on May 06, 2022, 02:51:24 PM
Folks,
Is any one able to access the download site for ACARSD? I wanted to download it and use it with RadarBox. But security does not allow this site for me. I have added what I thought would work for my browser.
Just want to obtain a copy to install.
Title: Re: Trying to obtain ACARSD for RB
Post by: Runway 31 on May 06, 2022, 05:51:45 PM
I think the problem is with the ACARSD website being down
Post by: CountryEd on May 06, 2022, 07:47:23 PM
Bummer! That is what I was thinking. Now to just wait and see when the site returns. I have not seen any other freeware that does the ACARS.
Post by: abcd567 on May 07, 2022, 03:10:50 AM
The ACARSD software may not work properly (see screensht below):
https://www.rtl-sdr.com/rtl-sdr-radio-scanner-tutorial-receiving-airplane-data-with-acars/ (https://www.rtl-sdr.com/rtl-sdr-radio-scanner-tutorial-receiving-airplane-data-with-acars/)
Post by: abcd567 on May 07, 2022, 03:17:45 AM
You may try using AcarsDeco2 by Sergesero
Download from here:
https://github.com/abcd567a/mm2/releases/download/v1/acarsdeco2_windows_20181201.zip
Acarsdeco2 config
AcarSDeco2 v.20181201
Program options:
  -h [ --help ]              This help message
  --device-list               List available SDR devices
  --device-index arg      Select SDR device (default: 0)
  --device-serial arg      Select SDR device by serial number
  --gain arg                  Set preamp gain of receiver, dB (default: auto)
  --freq-correction arg   Set oscillator frequency correction, ppm (default: 0)
  --agc                         Enable automatic gain control in SDR chip (default:off)
  --freq arg                   Set receiver frequency, Hz
                                   Specify option --freq multiple times to multiple
                                   channels (Example: --freq XX --freq YY ...)
  --inConnect arg           Input connector. Format: (sbs|ad2):host:port
  --inConnectId arg        Named input connector. Format: (sbs|ad2):host:port:ID
  --inServer arg             Input server. Format: (sbs|ad2):port
  --inServerId arg          Named input server. Format: (sbs|ad2):port:ID
  --inServerUdp arg        Input UDP server. Format: (sbs|ad2):port
  --outServer arg           Output server. Format: (sbs|ad2|pp):port
  --outConnect arg         Output connector. Format (sbs|ad2|pp):host:port
  --outConnectUdp arg   Output UDP connector. Format: (sbs|ad2|pp):host:port
  --http-port arg            Set port for http server (default: 8080)
  --vrs-url arg               Set VirtualRadarServer url for additional aircraft data
                                   Example: http://example.com (default: off)
  --pictures-url arg        Set aircraft pictures collection url
                                   Example: http://site.com/path/to/ (default: off)
  --pictures arg             Set aircraft pictures collection local path
  --silhouettes arg        Set path to directory of aircrafts' silhouettes
  --banners arg            Set path to directory of operators' logos
  --frdb arg                  Set path to flightroutes database file
  --db arg                    Set path to basestation database file
  --no-uplink                Don't display uplink messages (default: on)
  --no-sq                     Don't display messages with SQ label (default: on)
  --no-empty               Don't display empty messages (default: on)
  --logfile arg               Set path to log filename (default: off)
  --logfile-sbs arg         Set path to SBS CSV log filename (default: off)
  --logfile-esbs arg       Set path to extended SBS CSV log filename (default:off)
  --no-console              Disable logging on console (default: on)
Press any key to continue . . .
