AirNav Radar => AirNav Radar Discussion => Topic started by: DZpower on July 16, 2022, 01:41:46 PM
Title: MLAT not working after Raspi update and selecting yes instead of no for rbfeeder
Post by: DZpower on July 16, 2022, 01:41:46 PM
My MLAT does not work since i did an update on my Raspi
i did re-install RBFEEDER via CLI  but still no luck with getting MLAT back
Title: Re: MLAT not working after Raspi update and selecting yes instead of no for rbfeeder
Post by: DZpower on July 16, 2022, 01:42:55 PM
i can provide logs upon request and would appreciate any help or suggestion
Post by: abcd567 on July 16, 2022, 02:21:24 PM
(1) First run this command
sudo apt update
(2) Next issue following commands and post their output
uname -a
lsb_release -a
apt-cache policy rbfeeder
apt-cache policy mlat-client
apt-cache policy python3
(3) Also post output of following command (replace key by xxxxxx when posting)
cat /etc/rbfeeder.ini
Post by: DZpower on July 16, 2022, 06:43:44 PM
when i run the sudo apt  update it does show that it's all up to date
When i run the sudo nano command
[client]
network_mode=true
key=xxxxxxxx
sn=EXTRPI026653
lat=42.381765999999999
lon=-71.097617
alt=41
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client
[dump978]
dump978_enabled=false
Post by: DZpower on July 16, 2022, 06:48:29 PM
 Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
rbfeeder:
  Installed: 1:1.0.8+deb10
  Candidate: 1:1.0.8+deb10
  Version table:
*** 1:1.0.8+deb10 500
mlat-client:
  Installed: 0.2.11
  Candidate: 0.2.11
  Version table:
*** 0.2.11 500
Post by: DZpower on July 16, 2022, 06:53:43 PM
it does not allow me to copy and past result of  the rbfeeder  this post bock it as spam or some filters
i see a a lot of errors
PermissionError: [Errno 13] Permission denied: '/run/ml
  open(pidfile, 'w').write(pid)
usr/bin/mlat-client", line 108, in <module>
Post by: DZpower on July 16, 2022, 06:56:59 PM
i see some errors
"PermissionError: [Errno 13] Permission denied: '/run/mlat-client.pid"
File "/usr/bin/mlat-client", line 108, in <module>
PermissionError: [Errno 13] Permission denied: '/run/mlat-client.pid'
Traceback (most recent call last):
File "/usr/bin/mlat-client", line 108, in <module>"
Post by: DZpower on July 16, 2022, 07:03:05 PM
Quote from: abcd567 on July 16, 2022, 02:21:24 PM
sudo apt update
uname -a
lsb_release -a
.please check your private message
Post by: abcd567 on July 16, 2022, 09:45:03 PM
Seems mlat-client installed from RB24 site (using command sudo apt install mlat-client) has some defect. Better purge it, then build & install from source code
(1) First purge existing package
sudo apt purge mlat-client
(2) Install dependencies and tools required to build package from source-code
sudo apt update -y
sudo apt install -y git curl build-essential debhelper python-dev python3-dev
(3) Downloaded source code and build mlat-client's installation package.
cd
cd mlat-client
sudo apt install -y dh-python
sudo dpkg-buildpackage -b -uc
(4) Install newly built package by following command
cd
Post by: DZpower on July 17, 2022, 01:51:49 AM
worked like a charm :)
Thank You so much :) Kudos to your expertise
Post by: abcd567 on July 17, 2022, 12:00:17 PM
Glad to know your problem is solved   :)
Post by: abcd567 on July 18, 2022, 04:21:36 PM
When in future any update/upgrade command is run, it will replace healthy mlat-client (which you have built yourself) by the defective mlat-client from RB24 repository.
To prevent this, put your mlat-client on hold by following command
sudo apt-mark hold  mlat-client
The responce to above command will be:
mlat-client set on hold..
Post by: Runway 31 on July 18, 2022, 05:19:29 PM
abcd, have you advised Airnav  of their defective MLAT client?  If not are you aware of the defect and I can advise
Post by: abcd567 on July 18, 2022, 05:45:09 PM
Alan, no, I have not advised AirNav about the defective mlat client because:
(1) up till now only 2 cases have been reported in forum
(2) I cannot make out what is exactly the defecti, is it because of a corrupted files or because of some changes made by RB24 developers in the source code.
If you like you can inform support with links to the two lates threads  on this issue.
abcd
Post by: Runway 31 on July 18, 2022, 06:28:49 PM
Thanks, will do
Post by: jayant on October 25, 2022, 11:06:32 AM
I can report that I had the same problem and fixed it by building the mlat-client from github.
Post by: Joejoe1 on October 27, 2022, 05:08:02 PM
I am here because of this issue. Your solution @abcd567 solved it for me, thank you very much!
Post by: RZEE on December 11, 2022, 09:28:45 AM
QuoteWhen in future any update/upgrade command is run, it will replace healthy mlat-client (which you have built yourself) by the defective mlat-client from RB24 repository.
Code: [Select]
Can this made undone? if so what's the command for this?
Thanks in advance
Post by: abcd567 on December 12, 2022, 08:37:33 PM
Quote
Code: [Select]
Thanks in advance
Yes, it can be undone by following command
sudo apt-mark unhold mlat-client
Responce:
Canceled hold on mlat-client.
Post by: RZEE on December 13, 2022, 06:32:10 PM
QuoteYes, it can be undone by following command
Responce:
Works! Many thanks again.
Post by: Runway 31 on December 13, 2022, 07:24:27 PM
Please note that I have been advised as follows that a new MLAT client is available which should fix the previous issue
Package mlat-client is updated in our repository using the latest published version from mutability (0.2.11), but ours is "1:0.2.13" just because we need to change version number to 'force' apt-get to understand that is a new version (the code is the same).
Should work for every new installation by now.
Note that the packages are updated only for the latest (current) version of raspbian OS (AKA Bullseye), not for older versions (buster). If we have A LOT of users running older OS's, we can create a package for that.....but my recommendation is to update the operating system.
Let me know if it is OK
Post by: RZEE on December 15, 2022, 06:59:24 PM
The installation of the flight feeder works ok, there are still issues installing airband.
E: Unable to locate package rtl-airband-rb
Post by: Runway 31 on December 15, 2022, 07:15:16 PM
Airband has nothing to do with ADSB mlat client totally seperate install, ask support to direct to Airband package
Post by: RZEE on December 18, 2022, 07:41:55 PM
Hi Alan,
QuoteAirband has nothing to do with ADSB mlat client totally seperate install, ask support to direct to Airband package
I expect most of the users including me are aware of this. Your advice to update to bullseye i do not understand, as the transition to Bullseye will break many of the users setup if they have airband included. Radarbox should update their website and include a working airband for Bullseye. Remember Bullseye is released more than 1 year ago......
Post by: Runway 31 on December 18, 2022, 07:56:33 PM
It is not my advice it comes from the developer responsible for Linux, if you dont want to do it dont do it.   His advice is based on ADSB requirement not VHF
Regarding your request for Bullseye airband I suggest you contact Airnav with that request as I previously suggested
Post by: ramon.cutanda on August 28, 2023, 10:46:36 AM
SOLVED See my next message (https://forum.radarbox24.com/index.php?topic=106441.msg557681#msg557681).
I have been feeding for radarbox for several months now, but I had to reinstall my Rasperry OS and I decided to use the lastest (for the time being) Pi OS based on Bullseye instead of my previous Buster. The default install for MLAT never worked in my setup:
sudo apt-get install mlat-client -y
In order to have MLAT working I had to use the mlat-client_0.2.11_BUSTER_armhf.deb from this repo:
https://github.com/abcd567a/mlat-client-package/releases/
And then block the regular update:
Now, with Bullseye however, I am completely unable to make MLAT works for radarbox. I have tried both the default install:
And also the mlat-client_0.2.11_BULLSEYE_armhf.deb package from https://github.com/abcd567a/mlat-client-package/releases.
This is my setup:
@raspberrypi:~ $ cat /sys/firmware/devicetree/base/model
Raspberry Pi 4 Model B Rev 1.2
@raspberrypi:~ $ uname -a
Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 11 (bullseye)
Release:        11
Codename:       bullseye
@raspberrypi:~ $ apt-cache policy rbfeeder
rbfeeder:
  Installed: 1:1.0.8+deb11
  Candidate: 1:1.0.8+deb11
  Version table:
*** 1:1.0.8+deb11 500
        500 https://apt.rb24.com bullseye/main armhf Packages
        100 /var/lib/dpkg/status
@raspberrypi:~ $ apt-cache policy mlat-client
mlat-client:
  Installed: 1:0.2.13+deb11
  Candidate: 1:0.2.13+deb11
  Version table:
*** 1:0.2.13+deb11 500
@raspberrypi:~ $ apt-cache policy python3
python3:
  Installed: 3.9.2-3
  Candidate: 3.9.2-3
  Version table:
*** 3.9.2-3 500
        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
@raspberrypi:~ $ sudo systemctl status rbfeeder
     Active: active (running) since Mon 2023-08-28 12:31:56 CEST; 8min ago
    Process: 669 ExecStartPre=/bin/mkdir /var/run/rbfeeder (code=exited, status=0/SUCCESS)
    Process: 682 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/run/rbfeeder (code=exited, status=0/SUCCESS)
    Process: 690 ExecStartPre=/bin/touch /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 698 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 702 ExecStartPre=/bin/chown rbfeeder:rbfeeder /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
    Process: 708 ExecStartPre=/bin/setfacl -m u:www-data:rwx /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
   Main PID: 711 (rbfeeder)
      Tasks: 9 (limit: 1599)
        CPU: 1.784s
             └─711 /usr/bin/rbfeeder
Aug 28 12:37:13 raspberrypi rbfeeder[711]: [2023-08-28 12:37:13]  Data sent: 14.6 KB
Aug 28 12:37:13 raspberrypi rbfeeder[711]: [2023-08-28 12:37:13]  Data received: 31 B
Aug 28 12:38:14 raspberrypi rbfeeder[711]: [2023-08-28 12:38:14]  ******** Statistics updated every 60 seconds ********
Aug 28 12:38:14 raspberrypi rbfeeder[711]: [2023-08-28 12:38:14]  Packets sent in the last 60 seconds: 58, Total packets sent since startup: 368
Aug 28 12:38:14 raspberrypi rbfeeder[711]: [2023-08-28 12:38:14]  Data sent: 17.0 KB
Aug 28 12:38:14 raspberrypi rbfeeder[711]: [2023-08-28 12:38:14]  Data received: 31 B
Aug 28 12:39:15 raspberrypi rbfeeder[711]: [2023-08-28 12:39:15]  ******** Statistics updated every 60 seconds ********
Aug 28 12:39:15 raspberrypi rbfeeder[711]: [2023-08-28 12:39:15]  Packets sent in the last 60 seconds: 58, Total packets sent since startup: 426
Aug 28 12:39:15 raspberrypi rbfeeder[711]: [2023-08-28 12:39:15]  Data sent: 19.3 KB
Aug 28 12:39:15 raspberrypi rbfeeder[711]: [2023-08-28 12:39:15]  Data received: 31 B
@raspberrypi:~ $ sudo systemctl status mlat-client
● mlat-client.service - LSB: Multilateration client
     Loaded: loaded (/etc/init.d/mlat-client; generated)
     Active: active (exited) since Mon 2023-08-28 12:31:42 CEST; 8min ago
       Docs: man:systemd-sysv-generator(8)
    Process: 379 ExecStart=/etc/init.d/mlat-client start (code=exited, status=0/SUCCESS)
        CPU: 98ms
Aug 28 12:31:41 raspberrypi systemd[1]: Starting LSB: Multilateration client...
Aug 28 12:31:42 raspberrypi mlat-client[379]: Not starting mlat-client daemon, disabled via /etc/default/mlat-client ...
Aug 28 12:31:42 raspberrypi mlat-client[465]:  (warning).
Aug 28 12:31:42 raspberrypi systemd[1]: Started LSB: Multilateration client.
@raspberrypi:~ $ cat /etc/rbfeeder.ini
[client]
network_mode=true
key=***********************
sn=EXTRPI005044
[network]
mode=beast
external_port=30005
[mlat]
autostart_mlat=true
[dump978]
I am also feeding for FR24:
@raspberrypi:~ $ fr24feed-status
FR24 Feeder/Decoder Process: running.
FR24 Stats Timestamp: 2023-08-28 10:41:23.
FR24 Link: connected [UDP].
FR24 Radar: T-LEMI21.
FR24 Tracked AC: 3.
Receiver: connected (16773 MSGS/0 SYNC).
FR24 MLAT: not running ... failed!
@raspberrypi:~ $ sudo cat /etc/fr24feed.ini
receiver="beast-tcp"
fr24key="582b0713bf2f7221"
host="127.0.0.1:30005"
bs="no"
raw="no"
logmode="0"
logpath="/var/log/fr24feed"
mlat="no"
mlat-without-gps="no"
Any help will be greatly appreciated.
Kind regards,
Post by: ramon.cutanda on August 28, 2023, 11:31:53 AM
I found the solution to my problem here:
https://forum.radarbox24.com/index.php?topic=101771.msg389571#msg389571
The section [client] of my rbfeeder.ini lacked the info about latitude, longitude and altitude:
lat=xx.xxxxxx
lon=yy.yyyyyy
alt=zzz
I hope this info will be helpful for others, but perhaps you could consider adding this info into the official guide:
https://www.radarbox.com/sharing-data/guide
Kind regards,
Post by: flygpagen on December 16, 2023, 12:20:22 PM
Quote from: abcd567 on July 16, 2022, 09:45:03 PM
sudo apt update -y
cd
cd mlat-client
cd
Hi! Trying to get the mlat-client to work for my station on Buster following this process, however I get an error message when compiling.
dpkg-buildpackage: info: source package mlat-client
dpkg-buildpackage: info: source version 0.2.13
dpkg-buildpackage: info: source distribution stable
dpkg-buildpackage: info: source changed by Oliver Jowett <[email protected]>
dpkg-buildpackage: info: host architecture armhf
dpkg-source --before-build .
debian/rules clean
dh clean --with python3 --buildsystem=pybuild
   dh_auto_clean -O--buildsystem=pybuild
        pybuild --clean -i python{version} -p 3.7
I: pybuild base:217: python3.7 setup.py clean
  File "setup.py", line 19, in <module>
    from setuptools import setup, Extension
ModuleNotFoundError: No module named 'setuptools'
E: pybuild pybuild:341: clean: plugin distutils failed with: exit code=1: python3.7 setup.py clean
dh_auto_clean: error: pybuild --clean -i python{version} -p 3.7 returned exit code 13
make: *** [debian/rules:10: clean] Error 13
dpkg-buildpackage: error: debian/rules clean subprocess returned exit status 2
Since Radarbox also says I need to update my RBFeeder I did so, but it turned out it was already latest version. Am I doing something wrong when compiling?
Post by: abcd567 on December 16, 2023, 09:02:53 PM
@flygpagen:
For Buster, no need to compile from source-code. The mlat-client package for Buster is available in Radarbox24 repositories, and can very easily be installed by following commands:
sudo apt update
s
Post by: flygpagen on December 17, 2023, 07:05:11 PM
Thanks for replying, but both my installs have MLAT-failure as reported in this thread also after update/re-install, so I tried the above.
Post by: abcd567 on December 17, 2023, 09:36:08 PM
Quote from: flygpagen on December 17, 2023, 07:05:11 PM
If you have OS Bullseye or Buster, and mlat-client installed from Radarbox repository by command sudo apt install mlat-client fail, then install mlat-client's package which I have eralier built from source-code and made these avaiable for download and installation from my Github site.
mlat-client-package (https://github.com/abcd567a/mlat-client-package)
Post by: DesertF0x on February 09, 2024, 08:31:57 AM
Quote from: flygpagen on December 16, 2023, 12:20:22 PM
No need to compile, just download the package:
wget https://github.com/abcd567a/mlat-client-package/releases/download/v1/mlat-client_0.2.11_BUSTER_armhf.deb
Purge the old package
Install the downloaded package
sudo dpkg -i mlat-client_0.2.11_BUSTER_armhf.deb
Deaktivate reinstallation on update
Post by: DesertF0x on February 09, 2024, 08:36:33 AM
Quote from: Runway 31 on December 13, 2022, 07:24:27 PM
Please update the package for BUSTER, too. This is so much easier than updating to BULLSEYE which might make a complete reinstall necessary.
I ran into this problem twice now and it just steals my time.
Providing the update makes it much easier for people to have their receiver working which should be high priority for RB.
Post by: Runway 31 on February 09, 2024, 01:21:43 PM
There are no issues with the current MLAT package for Buster.  The reply from me you gave was from 2022 and the MLAT package has been updated since then
Post by: DesertF0x on February 14, 2024, 09:55:45 AM
I ran into that problem a few days ago when doing a update on my Raspberry Pi and the version in the repo is still 0.2.11 which I downloaded in 2021.
mlat-client:
  Installed: 0.2.11
  Candidate: 0.2.11
  Version table:
     0.2.11 500
        500 https://apt.rb24.com buster/main armhf Packages
Post by: abcd567 on February 14, 2024, 05:37:04 PM
Quote from: DesertF0x on February 14, 2024, 09:55:45 AM
mlat-client:
  Installed: 0.2.11
  Candidate: 0.2.11
  Version table:
     0.2.11 500
You have Raspberry Pi OS BUSTER, which is too old.
Re-image your microSD card with BULLSEYE (or better with latest BOOKWORM), and install rbfeeder and mlat-client on it. You will get latest version of both.
Post by: DesertF0x on February 15, 2024, 08:37:40 AM
I know that I am on Buster. It is still supported! Not everyone has time to reinstall everything on every new release... .
Post by: abcd567 on February 15, 2024, 09:04:43 AM
Quote from: DesertF0x on February 15, 2024, 08:37:40 AM
If you are happy to stay with old OS Buster, then you should also be happy to stay with old version (0.2.11) of mlat-client.
Why are you complaining? What is wrong with mlat-client version 0.2.11?
Post by: DesertF0x on February 19, 2024, 07:08:24 AM
Because the version in the RB Repo is broken, see this thread and especially see here:
Quote from: DesertF0x on February 09, 2024, 08:36:33 AM
Post by: flygpagen on February 19, 2024, 06:02:52 PM
Quote from: abcd567 on December 17, 2023, 09:36:08 PM
Thanks, it is now running on both my locations.
