Hello everyone. I've recently bought a RB VHF stick and am using a Raspberry Pi 3B on Buster.
I have read the guide here https://www.radarbox.com/sharing-vhf
Something throwing me off is the bit about using RTL-SDR-Airband software. Clicking the link takes me to GitHub but I don't know what to do there.
If I just go straight to trying sudo apt-get update -y && sudo apt-get install rtl-airband-rb -y via ssh on the pi, I get the response "E: Unable to locate package rtl-airband-rb"
Is anyone pi savvy able to offer some guidance for me?
Thanks in advance.
You need to add Radarbox repository to your apt sources list.
(1) EASY AUTOMATED METHOD:
If you don't have RBFeeder installed, the following command will install both RBFeeder and the rtl-airband-rb package:
sudo bash -c "$(wget -O - http://apt.rb24.com/inst_rtl-airband-rb.sh)"
(2) MANUAL METHOD (FOR ADVANCE USERS)
The screenshot you posted shows you have Raspbian BUSTER.
You can further confirm this by following command
lsb_release -sc
Issue following command to add RB24's BUSTER repo to your apt sources list:
sudo touch /etc/apt/sources.list.d/rb24.list
sudo chmod 666 /etc/apt/sources.list.d/rb24.list
sudo echo 'deb https://apt.rb24.com/ buster main' > /etc/apt/sources.list.d/rb24.list
sudo chmod 644 /etc/apt/sources.list.d/rb24.list
sudo apt update
Now issue following command to install airband
Thanks abcd! I was hoping you come good having read so many of your posts before.
I'll have a go now and report back.
There seems to be an error with that
Try this command:
Ok, that's done and the conf file is now populated with the information provided in the guide.
My issue now is restarting the service.
The service is not found.
Here's the error
Failed to restart rtl-airband-rb. Unit rtl-airband-rb.service not found
The airband did NOT get installed.
The problem is missing PUBLIC KEY F2A8428D3C354953 (see cutout from your first screenshot below)
Add missing key by following command
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys F2A8428D3C354953
Now try again
Thank you! All seems to have gone through correctly. Only issue now is it shows offline on the website which is a little odd
@abcd567
I seem to have another issue which is causing the service to fail.
If I issue the command sudo systemctl restart rtl-airband-rb.service
I get the following error
Job for rtl-airband-rb.service failed because the control process exited with error code.
See "systemctl status rtl-airband-rb.service" and "journalctl -xe" for details.
Running this systemctl status rtl-airband-rb.service
offers the response
● rtl-airband-rb.service - SDR AM/NFM demodulator
Loaded: loaded (/lib/systemd/system/rtl-airband-rb.service; enabled; vendor preset: enable
Active: failed (Result: exit-code) since Fri 2022-09-30 19:50:54 BST; 2min 18s ago
Docs: https://github.com/szpajder/RTLSDR-Airband/wiki
Process: 3564 ExecStart=/usr/bin/rtl_airband -e -c /etc/rtl-airband-rb.conf (code=exited, s
Sep 30 19:50:54 raspberrypi systemd[1]: Starting SDR AM/NFM demodulator...
Sep 30 19:50:54 raspberrypi rtl_airband[3564]: Error while parsing configuration file /etc/rt
Sep 30 19:50:54 raspberrypi systemd[1]: rtl-airband-rb.service: Control process exited, code=
Sep 30 19:50:54 raspberrypi systemd[1]: rtl-airband-rb.service: Failed with result 'exit-code
Sep 30 19:50:54 raspberrypi systemd[1]: Failed to start SDR AM/NFM demodulator.
Looking now at the code for the config using sudo nano /etc/rtl-airband-rb.conf
shows the below which seems to relate to the 3 dots on line 6
The code was originally copied and edited where needed from here https://www.radarbox.com/sharing-vhf
Do you have any thoughts?
Here is the screenshot of the actual response
