I have both version 1.3 & 1.5, both don't run correctly after 15 minutes.
Maybe it comes from Windows XP or the firewall (I have Comodo Firewall)
The symptom : after 15 minutes, software screen is totally white (no menu, no windows, no data).
When if press CTRL+ALT+DEL: ANRB.exe don't answer
My config:
Core2Quad 6600 - 2.4GHz
Ram 2 Go
Graphic card : nVidia GeForce 8600GT
Can you confirm this happens after every 15 minutes, as it then sounds like a power save feature which is kicking in?
around 15 minutes. Power saves are disabled :/ (hard drive, etc..)
Send email a support with your elf file which can be found in the RadarBox directory and we will find the exact cause.
teh trouble is,now there is no problem ,lol
