AirNav Radar => AirNavRadar.com FAQ => Topic started by: Leoncio Daniel Guerrero R on January 26, 2024, 05:24:44 PM
Title: AirNav RadarBox does not obtain current information when consuming the JSON
Post by: Leoncio Daniel Guerrero R on January 26, 2024, 05:24:44 PM
ENGLISH
Hello, I explain the problem we have when using the AirNav RadarBox XRANGE,
At the time of consuming the JSON (IP/data/aircraft.json) it is returning the same
information, this is already happening continuously, we have identified
that we must disconnect the AirNav RadarBox XRANGE from the electrical current
and connect it again so that the reception of the
information through JSON appropriately
NOTE: Could there be a more updated version of Firmware that we don't have?
ESPAÑOL
Hola, expongo la problemática que tenemos al usar el AirNav RadarBox XRANGE,
al momento de consumir el JSON(IP/data/aircraft.json) esta regresando la misma
información, esto esta sucediendo ya de manera continua, hemos identificado
que debemos de desconectar el AirNav RadarBox XRANGE de la corriente electrica
y volverlo a conectar para que se vuelva a restablecer la recepción de la
información por medio del JSON de manera adecuada
NOTA: Podría haber alguna version mas actualizada de un Firmware que no tengamos?
Title: Re: AirNav RadarBox does not obtain current information when consuming the JSON
Post by: Runway 31 on January 26, 2024, 07:16:47 PM
I am not aware that you are able to intercept the data as it is a closed system sending the data back to Airnav for display on radarbox.com
However contact [email protected] for advice
