AirNav Radar => AirNav Radar Discussion => Topic started by: jwyman on November 02, 2024, 04:20:09 PM
Title: Small number of flights showing on web
Post by: jwyman on November 02, 2024, 04:20:09 PM
Hello All,
  I have recently seen a large decrease in flights showing up on my radarbaox 24 web site.
However, if i use the PC-based Airnav radarbox application, I have over double the amount of flights.
Title: Re: Small number of flights showing on web
Post by: Runway 31 on November 02, 2024, 08:26:25 PM
I suggest you contact support with your query
Post by: VK5ATN on November 03, 2024, 02:37:41 AM
I have the same problem.
I have one Raspi and the RF hardware feeding to both Radar Box and Flight Aware.   My Radar Box page is only showing between a quarter and a half of the flights that Flight Aware is painting - both from the same antenna /receiver and Raspi feed.   Up unto a few days ago the numbers were pretty well the same - which is what I would expect.  It changed suddenly on the morning (AU time) of the 1st November.
The deficiency is not related to range - it seems to be be totally random.  My ranking /score on the state and national pages appears not to have changed.
I actually have four separate Raspi stations feeding from this location / site.  The others (including one other Radarbox feed) are performing as they should.   These systems have been operating more or less normally now for around twelve months.
regards,
Terry
VK5ATN
Post by: Runway 31 on November 03, 2024, 05:28:34 PM
I have had a look at my station and am seeing the same issue, will report this
Post by: VK5ATN on November 03, 2024, 10:30:08 PM
Thank you - I've also made a report.
Post by: jcvieira on November 04, 2024, 08:43:22 PM
I confirm the problem. In my case, the loss exceeds 70% of the flights.
Post by: Runway 31 on November 04, 2024, 08:59:37 PM
Please advise [email protected] of your issue, the more reports the better
Post by: fabio2st on November 05, 2024, 05:51:16 AM
Hello everyone. I have the same issue in My Station, planes appear in the last flight tracked list but some of them not appear on the map, seems to be randomize. I will report this to support.
Post by: Runway 31 on November 05, 2024, 02:29:31 PM
I'm seeing a lot more flights on my station, looks to be fixed
Post by: jcvieira on November 05, 2024, 02:48:36 PM
Exactly! Now it seems that things are getting back to normal!
Post by: VK5ATN on November 05, 2024, 10:49:55 PM
My system has also returned to normal operation - both feeders showing the same numbers of aircraft.  Thanks to those concerned with the fix.   Unfortunately I've lost somewhere around 1500 - 2000 points in the score, and my previous places in the national and state rankings, but I should be able to claw that back again in time.
Thanks again Alan,
Terry
Post by: fabio2st on November 06, 2024, 02:39:17 PM
I can say everything seems to be ok.
Post by: jwyman on November 25, 2024, 06:08:07 PM
It happening again as of today 11/25/24  1:00 PM EST
