Have had a lot of missing data today in "myflights" (normally might get half a dozen or so) but when checking the "reporter" there have been more than 100!! & all on regular stuff (for my area) eg Ryanair, Ezy, Italy, Vistajet, Jet2 etc etc.......... have tried reboot, update db etc... any ideas guy's??
What data is missing Bob, is it the aircraft data, route data? When did you last update?
Can you give a couple of examples to allow me to investigate please
seem to remember summat similar happening years ago Alan, but can't remember what the solution was?? (version 6.02.003) & for reference it doesn't "activate" if you click on the line..
Cheers Bud.
Bob
Looking at your my flights and the 3 missing from it, 9H-QEP G-JZHU G-RUKC and having checked my Navdata all are in it and have been for some time. Can you confirm all are in yours
I would also check and see if you have more than one instance of the Navadata on your computer, as you are using 6.02.003 you will have updated your version of the V6 software, so every chance
Only 1 navdata & what program do you read it with bud?
File/Database Explorer/Select Table/Aircraft/ type the registration into Text to Find
Condition - IN Field AR
Click on find
Todays Navdata is 108053 kbytes so yours if OK should them the same or very similar, please check also
No & my nav is 75723?????? will update db again....
Use windows search and look for Navdata.db3 and see how many instances of it you find drag the larger Navdata into your radarbox/Data folder replacing the one in there
There is every chance there are Airnav files in program files, delete them
Thanks Alan,
I think it is sorted. Wonder why it puts that db etc that deep into c:... & not where the prg was installed? but no worries,
cheers again bud.
Hopefully thats it Bob, glad to have been able to help
