I have an airnav Radarbox 1,which up until a few months back was working. Suddenly aircraft stopped showing on my map, but they still show in my flight list and detail how far away they are from me. Is anyone using an RB1 and everything is still working? Did you have to do something to keep it working? Chatgpt tells me that Airnav has effectively withdrawn MLAT support for RB1 and as such aircraft will no longer plot on the map for me. I would be grateful for any advice.
The original boxes are still working and MLAT has never been available on these receivers, ADSB only
Try reloading the software again
Hi Alan,
I have reloaded the software multiple times but it doesn't fix this, which is why I am keen to hear from anyone else with an RB1.
Shawn
Is the map showing?
The map is showing and aircraft are appearing in my list. Aircraft with Adsb show how many miles they are away from me...but don't plot on the map.
Can you zoom out a few times just in case you have mistakenly zoomed in to far
It is definitely not a zooming issue. I have zoomed in and out but nothing showing
I'm out of ideas. I know other have suffered the issue but have no memory of how it was solved. Maybe someone else can remember
Thanks Alan. I am hoping someone who has had this issue will be able to let me know how they resolved it.
Have you tried logging in as ADMIN
can you please tell me how to log in as admin. Also one issue I noticed is that in advanced filters altitude was set to base 0 and top 0. Lat and long are not my Lat and Long and range was only 300. I have set top to 70000ft and changed range to max. Unfortunately this hasn't resolved the issue. When I log back on the details revert back. I assume there must be something simple I am not doing as the blue globe is showing next to aircraft in mylist, but just not plotting on the map. Sorry for taking up so much of your time, I am grateful for your advice.
Not sure about logging in as ADMIN
When closing down dont use the cross top right, use File/Exit that saves all changes made during the current sessions
Under Advanced on the line above map centre. make sure the top 4 picks are ticked
above the map click on home That worked for me on my RB1
I also have a RadarBox, which has stopped workingfor several days. I don't have the original boxes!
Support should be able to provide just tell them the PGANRB number
PGANRB400450
The thread is about the original boxes, not xranges
Have you tried re-booting the receiver
You will need to contact support with your PGANRB number and ask them to look into it. You will get them on
[email protected]Alan
I have tried everything. I will send out a message to them.
Glen
Good, only they can fix it. They are very busy however getting everything working on RB
