I keep on getting an error message Select at least 1 recipient. It started after I had activated an alert which would send an e-mail alert for a specific aircraft. I have since removed the alert condition and unchecked all the checked boxes under the alert tab but I still get the message and pop up alert. How can I stop this?
When are you getting the error message?
Have you set up Reporter to send a copy of your log to an email address without entering that address?
Ahhh thanks Allocator. Yes I had the Reporter checked with no e-mail addresses. Ill give it 24 hours to check if it does it again.
Thanks!
No problem :-)
