AirNav Radar => AirNav Radar Discussion => Topic started by: SteveB on August 27, 2008, 08:22:10 PM
Title: Network Flights
Post by: SteveB on August 27, 2008, 08:22:10 PM
Is there a network problem again i have no network flights?..i am currently getting 100+ on my flights and 130 msg per 30 sec...done a re-boot but still no network flights?
Title: Re: Network Flights
Post by: Longhorn on August 27, 2008, 08:32:44 PM
Same here no Network Flights...Please Advise
Post by: SteveB on August 27, 2008, 08:35:31 PM
Checked my firewall ARNB has permissions so it's not blocked....since the upgrade we seem to be loosing the network???
Post by: Terry on August 27, 2008, 08:46:42 PM
Looks like we`ve got a lot in common,my network has been going off intermittently since 20-00hrs,now has stopped completely.
Post by: AirNav Support on August 27, 2008, 09:44:15 PM
Apologies about the network, it is being investigated.
Post by: SteveB on August 27, 2008, 09:50:21 PM
Maybe we can have a header on the forum that says you have network problems...save all these posts...just a thought
Post by: AirNav Support on August 27, 2008, 09:53:56 PM
All you need to is the active stations network page on our site and if its working you know the network is fine :)
We do not always monitor the forum.
Post by: Terry on August 27, 2008, 10:14:08 PM
Network back on,but receiving 12 aircraft?
Post by: AirNav Support on August 27, 2008, 10:16:06 PM
Its still being rectified, you may see some weird data for the moment.
Post by: Terry on August 27, 2008, 10:17:05 PM
Thank you very much for yous quick response
Post by: AirNav Development on August 27, 2008, 10:52:35 PM
The Network is up and running again.
We have properly identified a network software problem that caused 2x 30 mins shortages in the last week. We are now developing a correction to it.
Post by: Bat 21 on August 28, 2008, 02:38:42 PM
15:30 uk time ...no network for me ..guess it's down.
From the main screen menu is it TOOLS > ACTIVE NETWORK LOCATIONS to check if the network is down .... I see nothing showing on the map at the moment but just wanted to check I was in the correct place
Bat 21
Post by: tarbat on August 28, 2008, 02:40:00 PM
Yes, looks like the network is down.  If there's nothing on the Active Network Locations map, then yes, the network is down.
Or just goto http://www.airnavsystems.com/radarbox/network.php
Post by: Deadcalm on August 28, 2008, 02:46:46 PM
Yes.  This is becoming a pain in the backside, and seems to be occurring more often.  I've been trying to watch a flight on which relatives are travelling, but been forced to give up.
What with this, and the continuing sluggishness of this programme, I'm beginning to wonder why I bothered...
In an earlier post, Airnav mentioned it didn't constantly monitor the forum - did they mean the servers?  Either way, maybe they should.
DC
Post by: Bat 21 on August 28, 2008, 02:48:02 PM
Cheers for the speedy reply tarbat,
network has just this second come back up and I can now see how the map looks when all is up and running.
Post by: AirNav Development on August 28, 2008, 02:55:36 PM
Deadcalm: the network was down for 30 minutes 2 times in the last 10 days.
In 1 year it was down not more than 2 hours. So maybe you would like to check your internet connection as if it happens so often there then it should be related to your configuration/installation.
Post by: tarbat on August 28, 2008, 02:59:16 PM
Quote from: Deadcalm on August 28, 2008, 02:46:46 PMIn an earlier post, Airnav mentioned it didn't constantly monitor the forum - did they mean the servers?  Either way, maybe they should.
I'm pretty sure they monitor the servers.  On the odd occasion that the network has gone down, they seem to get it back up and running very quickly.  Seems to be a very reliable service to me.
Post by: Bat 21 on August 28, 2008, 03:27:04 PM
Network gone a bit "wobbly" again....
I notice it seems to be trying to update every 3 seconds instead of every 30
couldn't have lost a zero off some default settings could we ?
Bat 21
Post by: AirNav Development on August 28, 2008, 03:28:27 PM
We are working on the network for the next 10 minutes.
Post by: AirNav Development on August 28, 2008, 03:32:27 PM
Our servers are of course monitored 24/7 by an external company and if the output is not as desired all the members of our team get alerts immediately. That's why since 2001 (when we launched the AirNav Live Flight Tracker application) the servers were down less than 4 times. The same happens with the RadarBox network.
Post by: AirNav Development on August 28, 2008, 03:50:44 PM
Tests finished. New server application working now and everything being monitored as usual 24/7.
Post by: Storm on August 28, 2008, 06:04:23 PM
God job boys!
