AirNav Radar => AirNav Radar Discussion => Topic started by: Storm on September 01, 2008, 03:11:59 PM
Title: KLM Routes problem
Post by: Storm on September 01, 2008, 03:11:59 PM
I started to notice KLM Route info problems. The routes are either reversed or not completed. I have only noticed this with KLM. However I also noticed a problem with a UAL out of Kuwait, ther route it shows is KIAD-KORD the origin OKBK is not there.
Title: Re: KLM Routes problem
Post by: AirNav Support on September 01, 2008, 03:15:54 PM
Can you check whether these routes were in the local database or downlaoded?
Post by: Storm on September 01, 2008, 03:53:05 PM
They were downloaded. Also I just noticed BAW125 the routing shown is OBBI-OTBD when it should be EGLL-OBBI-OTBD
I uninstalled and reinstalled the software but its still the same.
Post by: Storm on September 01, 2008, 03:54:23 PM
I changed the database but it always returns to the old incorrect data.
Post by: AirNav Support on September 01, 2008, 03:55:28 PM
There is known fault with multilegged flights. This is being looked at.
Post by: Storm on September 01, 2008, 04:05:27 PM
ok but why does it change back when I edit it in the DB?
Post by: Storm on September 01, 2008, 09:55:43 PM
No DLH is affected too. DLH637 is reading OKBK-OEDF when it should be OKBK-EDDF
Post by: AirNav Support on September 01, 2008, 09:59:35 PM
It overwrites the local database route as it does not match what is on the online database and hence it overwrites it.
