AirNav Radar => AirNav Radar Discussion => Topic started by: Kodos on October 25, 2008, 08:39:46 AM
Title: MyLog
Post by: Kodos on October 25, 2008, 08:39:46 AM
Hello
I've been using my new RadarBox for over 2 weeks without any problems until today.
When i select a flight in the MyFlights tab and do a right-click on it to open the log for this plane it inserts the right Mode S data to the quick filter but the flight displayed at the bottom is wrong. Tried it with different flights and the output is always flight BER407S.
I've also tried clearing the log using the tools menu. Problem stays the same, it now always shows the first flight picked up since then.
Any ideas?
Title: Re: MyLog
Post by: Kodos on October 25, 2008, 08:46:08 AM
Got it!
Somehow the filter used the wrong date (yesterday) even if the filter is set to "All Time", maybe i've found a bug?
Greets
Kodos
Title: Re: MyLog
Post by: RodBearden on October 25, 2008, 11:18:16 AM
Hi Kodos and welcome to the forum!
I've had similar experiences - I've found that you do sometimes have to select the correct date again or the filter doesn't work properly.
We need to investigate the circumstances better to file a bug report!
