Okay another minor issue (maybe!)
First I'll set the scene :)
When only using Live date and watching MyFlights currently have 15 live tracked flights, turn on Network and network is added as expected.
No problem so far....
Now turning off network, clears the MyFlights list to (0) and takes sometime to get back to the 15 tracked flights that were there 2 secs before.
Does that make sense ?
Its not a issue. Its like that so RadarBox is only handling one data source at that time and needs to refresh and start again.
It should not take too long to get back all your close flights within seconds (obviously ones further away may take time as you may only be getting intermittent messages from them due to reception)
Okay no problem, but did not seem to do that prior to Beta patch, or if it did I missed it. :)
