AirNav Radar => AirNav Radar Discussion => Topic started by: apjwright on November 23, 2008, 05:23:04 PM
Title: Updating the NavData DB
Post by: apjwright on November 23, 2008, 05:23:04 PM
So, I've been reading all of the threads I can find about how the NavData DB is supposed to update.  For the life of me, I cannot make it update.
I am sitting in my hotel room at the LHR Renaissance, running my RB and having a great time - now, if I could only get those new aircraft added to the DB !
Yes, I have a good internet connection.  What else do I need to do?
Can somebody outline some steps to test the update process?
In theory, once an aircraft record is updated, do you see it in the tracking view immediately, or do you have to exit the program and re-start?
Your help would be greatly appreciated in helping me through this issue.
Rgds,
Tony
Title: Re: Updating the NavData DB
Post by: Allocator on November 23, 2008, 05:57:16 PM
Do you have "Download photos selected"?  I'm sure that we found that there is a minor bug in 2009 that stops the autopopulate if you are not downloading the thumbnail photos.
Are you running the latest version - RadarBox 2009
The aircraft details will populate before your very eyes - providing your Firewall isn't blocking RB from connecting to the AirNav server.  Just click on an aircraft line in MyFlights that doesn't have any details and tell us what happens.
Post by: Blackthorn on November 23, 2008, 05:59:45 PM
I have found that you do need download photos enabled to auto populate.
Post by: apjwright on November 23, 2008, 06:19:48 PM
Thanks for the responses.
I fiddled around with the photo related settings (both the download photo's and display photo's) and have now got it working.
Thanks !
Does anybody know if the issue of having to turn on the photo settings for the autopopulate to work is going to fixed?  If so, when?
Tony
Post by: Allocator on November 23, 2008, 06:46:58 PM
Tony, it was fixed with an earlier version of RB, but I think that it slipped through the net with 2009.  As it's been fixed before, I'm sure that AirNav will have no problems fixing it again :-)
Post by: apjwright on November 23, 2008, 08:39:21 PM
Let's hope so !
Another question:  I've noticed that on quite a number of the 'newly updated' records, the type field comes in as '...' - why is that?
Thanks,
Tony
Post by: 9M-ISJ on November 24, 2008, 08:35:45 AM
I was wondering that too.... I have also had one or two come up with a reg but 'null' in the type box.
Is there a way to update these by hand?
Also will the database catch up with these by itself in time if left alone? Or will they always have ... or null on them??
Gulfstream
Post by: tarbat on November 24, 2008, 08:48:56 AM
Quote from: 9M-ISJ on November 24, 2008, 08:35:45 AMIs there a way to update these by hand?
Yes, using the Database Explorer.
Quote from: 9M-ISJ on November 24, 2008, 08:35:45 AMAlso will the database catch up with these by itself in time if left alone? Or will they always have ... or null on them??
They'll always have "..." or null in them.  Unfortunately if the data isn't populated on GAS, then Airnav can't get the aircraft type.
Post by: theripper on November 24, 2008, 04:56:37 PM
Quote from: tarbat on November 24, 2008, 08:48:56 AM
I still don't get it - when I check the online GAS database for a RB "..." entry, it includes the correct aircraft type in most cases. I deleted such an entry in the database explorer to see what would happen. RB then autopopulated the concerned aircraft, and again with "..." in the type field although GAS clearly has the correct data!
Post by: tarbat on November 24, 2008, 05:16:44 PM
Okay, that suggests that Airnav haven't got the updates from GAS.  Have you got an example?
Post by: theripper on November 24, 2008, 05:29:20 PM
Quote from: tarbat on November 24, 2008, 05:16:44 PM
Lots of, here's the most recent one:
3E2803 (D-IGIT)
Post by: tarbat on November 24, 2008, 05:36:21 PM
So, we need Airnav to explain whether the autopopulate routine on their servers is working from GAS, or has it stopped working again?
Post by: DaveReid on November 24, 2008, 06:19:46 PM
Quote from: tarbat on November 24, 2008, 05:36:21 PM
Could it be that, if the AirNav database has "..." in the ICAO code column, it treats that as a valid value and doesn't try to retrieve the actual code from GAS ?
Just a theory, but it seems to fit the circumstances described above.
Post by: tarbat on November 24, 2008, 06:23:31 PM
Agreed Dave.  I suspect that once the Airnav servers have got a record retrieved from GAS, that's it, and it doesn't try to get more recent updates from GAS.
Post by: 9M-ISJ on November 24, 2008, 10:24:02 PM
Just updated one of my records with null as the type in the Database Explorer, but it seems to still show with null in Mylog is that correct??
Would be interested to see what would show on screen when that a/c comes back into range
Post by: Allocator on November 24, 2008, 10:28:11 PM
MyLog is a historical record of what you have picked up live and the data comes from what was in the main (NavData) database at the time, so editing the main database won't affect what you already have in MyLog.
However, try MyLog > Tools > Populate as this looks at the main database to see if it can populate the records in MyLog.  I don't know if it will work if you already have some aircraft details in MyLog though.  It will populate "empty" MyLog records.
Post by: 9M-ISJ on November 25, 2008, 07:18:01 AM
I thought it might be something like that.
The populate method doesnt change anything I am afraid
I have masses of records with the ... type. Think this one needs addressing (so that anything with ... showing is included in population look ups)
Post by: 9M-ISJ on November 25, 2008, 07:41:32 AM
Just checked and in the four days I have been running RB I have over 150 aircraft showing the type short code as ... (way too many to amend by hand)
Very interestingly when viewing them in Database Explorer the vast majority of them have the correct aircraft type showing in the 'long name' box next to the short code.
I am wondering if it is something to do with RB and where-ever the data is pulled from (GAS?) inputting the long version of the type name slightly differently??
(ie if RN is looking for one thing, but finding a very slightly different version of the way the full type is expressed and hence doesnt put in the short code)
