like subject says i get no route information in the corresponding column ni the grid for any aircraft considering their route or where are they going, why ?
also data tracked show 2 hours behind than the actual GREECE time how do i change that ? I already stated my timezone in the software and said im in athens/greece so why airplanes tracked arent in my local time ?
cheers
asiawatcher,
Sorry I don't have an answer for you but I'm having trouble with routes not showing too. Even the routes I add manually and are saved don't appear.
I'm sure you do realize though that if there's no Flight ID then no route will show.
no everything shows except route info
any help would be appreciated
Do you have network aircraft turned ON? If so, then this is a known problem - see http://www.airnavsystems.com/forum/index.php?topic=1623.msg12800#msg12800
To adjust MyLog to local time, in Preference, tick the option for "Use Local Times for MyLog".
no i dont connect to network i chose to only see local traffic i dont care for network
cheers
If your not connect to the internet it cannot try and download the routes. The route data is not sent by the aircraft so we have to look it up using databases.
im connecting to the internet i just chose not to see network traffic do i have to be connected to both hardware and network traffic to see routes ??
cheers
Connecting to hardware allows you to see the local traffic.
Connecting to network traffic allows you to see other RB owners traffic.
I believe you need to be connected to network traffic to get routes.
asiawatcher, as long as you're connected to the internet, you should get route lookup on your local traffic. So, some diagnostic questions:
1. Do you get registrations okay? Do you get photos downloading okay?
2. Give us a few examples of Flight IDs where you're not getting the route.
yes everything is ok except routes they are missing
any flight id's really, yesterday it was klm1581 and swr1842 from swiss
all flights i get have no routes all of them im connected on the net but im not participating no the network traffic i only care for local one
cheers
Morning Gang
I'm not getting much route information on my logs yesterday i only had about 20 Routes showing out of 355 flights logged!!!!!
Flights which were showing routes last week are not showing now, anyone know why?
Brian Isle of Man
Strange. For me, out of 176 flights yesterday, 157 have routes.
Have you got any specific examples of Flight IDs that are not showing callsigns. And were you running with "Get Flight from Airnav Network" ticked?
Tarbat
Some examples from yesterday
7608FA PIA711 - AP-BGZ B772 Pakistan Internat... 2008/12/06 12:55:43
C0054D ACA838 C-FCAE B763 Air Canada 2008/12/06 11:24:43
C021FD ACA838 C-FMWQ B763 Air Canada 2008/12/06 14:32:13
C050B9 ACA847 C-GEOU B763 Air Canada 2008/12/06 10:35:20
4CA0BC EIN149 EI-CPC A321 Aer Lingus 2008/12/06 21:37:53
4CA0BB EIN149 EI-CPD A321 Aer Lingus 2008/12/06 20:36:30
4CA0D1 EI162 EI-CPE A321 Aer Lingus 2008/12/06 23:01:08
4CA0FD EGGW EI-CPF A321 Aer Lingus 2008/12/06 20:13:11
4CA0FE EIN151 EI-CPG A321 Aer Lingus 2008/12/06 12:06:05
4CA143 RY1425 EI-CSP B738 Ryanair 2008/12/06 09:58:39
4CA178 RYR1022 EI-CSR B738 Ryanair 2008/12/06 14:22:23
4CA1B5 RY776 EI-CTA B738 Ryanair 2008/12/06 22:34:49
4CA13D EIN154 EI-CVA A320 Aer Lingus 2008/12/06 17:43:43
40041E BA187 G-BNWD B763 British Airways 2008/12/06 19:47:08
4004E2 BAW098 G-BNWS B763 British Airways 2008/12/06 11:47:14
400525 BA097 G-BNWV B763 British Airways 2008/12/06 18:22:15
400557 BOS001 G-BPEK B752 British Airways 2008/12/06 06:53:12
* 400417 G-BUSH A320 British Airways 2008/12/06 13:41:11
400599 G-BVKB B735 Bmibaby 2008/12/06 12:36:38
4006B9 TCX353L G-BXKB A320 Thomas Cook Airlines 2008/12/06 20:46:29
40073D BA117J G-BYGE B744 British Airways 2008/12/06 09:34:22
400B8A GSM217 G-CDEG B738 Flyglobespan 2008/12/06 18:42:35
this is just a few
Brian
so where are the routes from that paste ? it displays the route as code only not displaying the actual destination in words ?
in my grid under the ROUTE its empty while it should say.. LUTON for example right ?
asiawatcher, you should see the route displayed using ICAO codes in the MyFlights list, and as airport names in the aircraft details box - example attached.
right i dont get route only registration, then how do i look up the actual route from registration ? like its going to paris or london for example ?
cheers
yes tarbat it is ticked
Quote from: HMN851X on December 07, 2008, 05:21:03 PMyes tarbat it is ticked
Okay, then this is the known issue where the route is not checked locally if flight transitions from network to local. Will hopefully be fixed in v2.1.
Quote from: asiawatcher on December 07, 2008, 04:51:58 PMright i dont get route only registration, then how do i look up the actual route from registration ? like its going to paris or london for example ?
You'll only get a route if the aircraft has a Flight ID.
yes tarbat i got all the flight id's but unfortunately NO ROUTE
see here --> http://asiawatcher.net/help/
Okay, I'm out of ideas, sorry. At least 2 of those Flight IDs are in my routes table. Are the Flight IDs in your routes table? Maybe contact Airnav support for help.
Asiawatcher,
Open your Routes Database in RadarBox. File -> Database Explorer - Choose Routes for the table. Scroll down to the bottom, do you see values in the the CH column?
Also did you use upgrade to RadarbOX 2009 or have you always been using RadarBox 2009?
Hi CH column is empty all along, no values
I have always been using radarbox 2009 as i bought the hardware 2 days ago
i downloaded the version you got on website first
http://www.airnavsystems.com/download/anrb/anrb20setup.exe
to check out the demo 1 day before i buy radarbox then i seen that on the cd provided it has a slightly newer version called ANRB201Setup.exe
so then i installed that version over the 20 one i think without uninstall
do i need to uninstall and reinstall ?
cheers
