AirNav Radar => AirNav Radar Discussion => Topic started by: Jetcos on August 18, 2007, 03:07:48 PM
Title: USB Extenders
Post by: Jetcos on August 18, 2007, 03:07:48 PM
Found reference in a search of the Forum and am wondering if this would be a good way to have the supplied antenna moved closer to the outside of my house. My original plan was to use my discone antenna but it does not work (no messages) and I would like to run RB all day. Will a USB Extender allow me to run the computer at one end of the house and have the RB and antenna at the other end?  75 feet would be the distance.
TIA
Steve
Toronto
Title: Re: USB Extenders
Post by: AirNav Support on August 18, 2007, 06:46:09 PM
Hi Jetcos,
USB extenders sometimes has mixed results. In some cases they work perfectly but some people have interference over the wires over such a distance and they end up loosing there USB connection and having to restart RadarBox.
Hope that helps.
Post by: Jetcos on August 22, 2007, 09:38:41 PM
Thanks for the reply
Post by: Roadrunner on August 23, 2007, 08:20:40 AM
What we could do with is the ability to either have an ethernet connection, or better still a wireless connection between the RadarBox and thwe PC - now that is something for AirNav to think about
Post by: marcdeklerk on February 16, 2008, 04:24:56 PM
Will this work with RB?  --Belkin USB Wireless Hub
http://cgi.ebay.com/Belkin-USB-Wireless-Hub-Model-F5U303-NEW_W0QQitemZ160208964387QQihZ006QQcategoryZ31495QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post by: Pallmall68 on February 16, 2008, 11:24:01 PM
I have a USB extender and 15 meter of cable and my RB work very good.
Post by: Dub33 on February 17, 2008, 11:31:33 AM
Hi Pallmall68
What kind of USB extender & cable are you using?
Post by: Allocator on February 17, 2008, 11:38:33 AM
I use the Maplin USB extender which allows you to use up to 45m Cat 5 network cable.  It works a treat, although this isn't available from Maplin any more. The power for RadarBox is provided by the extender. There are other versions out there if you do a Google search.
http://www.maplin.co.uk/free_uk_delivery/USB_Extender_45471/USB_Extender_45471.htm
Here is the result of a quick Goole search:
http://www.nti1.co.uk/usbc5.html
http://www.cyberguys.com/templates/SearchDetail.asp?productID=7707
http://www.lindy.co.uk/usb-extension-cat5-usb-extender-premium-up-to-50m/42801.html
Post by: Jetcos on February 17, 2008, 03:11:37 PM
I bought a USB extender and run cable to the RB that let's me put the antenna outside for better signals. I went to the USB and de-selected the option to turn off the USB port to save power. Still find the USB connection is off and I have to disconnect and re-connect the plugs. Any suggestions on keeping it going?
TIA
Steve
Post by: AirNav Support on February 17, 2008, 03:36:01 PM
Jetcos,
How long in total is the USB connection now?
Post by: Dub33 on February 17, 2008, 10:43:21 PM
Allocator,
Thanks for the response regarding the USB extender..
Much appreciated
Post by: Jetcos on February 18, 2008, 01:37:09 AM
Seems to last 4-5 hours, hard to say as I haven't checked on the times (from first message to last received) but will try to figure it out.
Steve
Post by: piper-pilot on February 18, 2008, 09:34:15 AM
Quote from: marcdeklerk on February 16, 2008, 04:24:56 PM
Yes it will but I get drop outs from time to time. Not sure if it is wireless range or limited USB functionality
Post by: Pallmall68 on February 18, 2008, 08:21:08 PM
Dub33,  i have a Maxxtro USB repeater UB431 (5 meter) and a standard 10 meter USB Cable.
Post by: juangelb on February 20, 2008, 10:49:43 AM
Hi People.
I`M using a Ubox with two RBs at this time, one for home and the second to use remotely trough the internet, working pretty fine.
http://www.lantronix.com/device-networking/external-device-servers/ubox.html
Best resgards. Juan
Post by: Dub33 on February 22, 2008, 10:31:54 AM
Cheers Pallmall68
Dub33
Post by: Jetcos on February 25, 2008, 10:49:48 PM
Had it running today from 07:15 am till it stopped at 13:20pm.  Not very long, will wait for V1.4 and see if it helps.
Steve
Post by: AirNav Support on February 25, 2008, 10:51:36 PM
Jetcos,
Confirm you have 1.3 running? as 1.4 won't affect stability of USB connections as that should be fine under 1.3 (it should reconnect if the USB drops)
If you are using 1.3 then its simply the length of the USB cable which is causing the drop out.
Post by: Deadcalm on February 28, 2008, 09:37:08 AM
Juan, where did you get your Lantronix unit from?  There doesn't seem to be the facility to order it directly from them on line, and I can't find a French reseller.  I'd like to get hold of one of these units fairly quickly.
DC
