Hello everybody,
I would like to refer to the direction vector on the screen, is moving late compared to airplane label. I notice this since Airnav has launched version 6.0.002. And now with version 60003 the problem persist. Nobody noticed this if you set screen refresh rate to 1sec.?
Maybe some people will tell me to set the screen refresh rate greater then 2 or 3 sec. But is ADS-B signal so, the position report is updated once per second.
The direction vector must move first and not with delay" behind" the airplane label.
With version 3.13 the direction vector is moving correctly and I would like to use that version but unfortunately the duplicate flights still a big problem there.
Also, if you set the seconds to mark a flight as timeout to less then 8 sec, it will not work.
Now I ask : why nobody try to fix this problems before the software is released?
