AirNav Radar => AirNav Radar Discussion => Topic started by: markyeulett on September 04, 2007, 11:01:29 AM
Title: My Log Database
Post by: markyeulett on September 04, 2007, 11:01:29 AM
Can anyone help - in which file on the PC is the my log data stored?  Is it possible to export this to excel or a txt file?
Title: Re: My Log Database
Post by: AirNav Support on September 04, 2007, 01:15:49 PM
You can't export it to a different file however can see why you would want too and will put it down as a future request.
If you want backup your database its best to backup the whole Data folder in AirNav RadarBox folder. You don't need to backup the photos if they are too large to fit into your backup medium.
Hope that helps.
Post by: markyeulett on September 04, 2007, 01:38:22 PM
So there is not a specific file that capures and stores the data?
Post by: AirNav Support on September 04, 2007, 01:55:46 PM
There is but you might get errors if other files are missing in that folder which do not match up.
Post by: Roadrunner on September 04, 2007, 02:11:15 PM
Quote from: AirNav Support on September 04, 2007, 01:15:49 PM
Hope that helps.
If you do give us that facility - could we ask for some "user available" fields that we can edit externally (say in Access or Excel) with whatever we want, and for the ability to return the modified file to Radar box.  Example in SBS1 I always use the User field to record the date/time/location of aircraft I manage to eyeball - as well as being seen by the system.
