This aircraft is currently heading towards West Freugh heading SE. Why do I get the details on the interface as 3F8517 GAF 256 10+23 A310 but the picture wont load and it says Russia Airforce 10 23 Antanov AN-26?
Initial Shipped database errors.
I deleted the record from the aircraft DB.
Stopped and restarted the Process Hardware flights.
The AirNav servers populated the details correctly.
The Photograph may be incorrect as it is linked by Registration and many Air Forces use similar Numeric ID's.
CanonsJohn
Photos for German aircraft have been explained many times on the forum. The + symbol acts as a divider in the airliners.net photo search. Instead of the system searching airliners net for registration '10+23' It searches for a registration that photo whose data field contains the number 10 and seperately the number 23.
If you go to airliners.net and type 10+23 into the quick search, you will see what I mean.
It is better to use database explorer to remove the iron cross as all German mil aircraft are loaded onto airliners.net without it. This aircraft photo will be found if you change the registration to '1023'
Cheers ACW367. I'm getting there honestly, as aways thanks for the help.
