AirNav Radar => AirNav Radar Discussion => Topic started by: dl1812 on February 16, 2009, 01:33:55 PM
Title: Saving Changes
Post by: dl1812 on February 16, 2009, 01:33:55 PM
Hi All,
I change various items on the Map, etc., to make it easier for me to pick stuff out.
Foe Example, changing Airports outlines to pale grey shows them up better, and changing the altitudes to filter out stuff close to landing.
However, I cannot then see how to save these changes - I always use File_Exit to close down, but the next time I open up, all my changes have gone.
Any suggestions gratefully received.
Dave Long
Title: Re: Saving Changes
Post by: jgrloit on February 16, 2009, 01:40:06 PM
Map  - Open/Save Map  - Save Map   or Save map As
Use a new name if saving AS.
Post by: dl1812 on February 16, 2009, 01:57:00 PM
Dur !
I knew it had to be something straightforward....thanks for that :o)
Post by: dl1812 on February 16, 2009, 03:55:03 PM
Sorry - back again; didn't work.
Saved as default, Default2, Home2, but after a File_Exit and starting it back up again, everything is as it was.
Do I therefore have a software glitch of some sort ?
Dave
Post by: drskeptical on February 16, 2009, 04:07:56 PM
Hi dl1812
I have a similar problem. I use Vista 32 if that means anything. But I make my changes and save them in the way described above.
When I launch the program again it SOMETIMES comes on with my changes,  or more often than not, comes on with the default colours.
I then just go into map colours and re load my default map. I have tried using a different map names and overwriting the default.
It makes no difference. For me, it is not the end of the world. I can live with it, I just put it down to a vista thing.
Post by: besty on February 16, 2009, 04:11:29 PM
Did you use the default settings when you installed RB in Vista? cvould be somethign to do with the virtual store.
Post by: RodBearden on February 16, 2009, 04:18:56 PM
I have the same problem, and I'm on XP.
AirNav know about the problem, but, as you say it's something we can live with - just a niggle.
Post by: dl1812 on February 16, 2009, 04:31:48 PM
I'm running XP on my Company Laptop, and Vista on my Home Laptop, and it seems to be the same for both.
I'm just grateful that it's it's not me !
Thanks for that, Gentlemen - it can be lived with.
Thanks to All
Dave
Post by: tarbat on February 16, 2009, 04:33:45 PM
I suspect there may be a problem with the registry permissions for the settings used by Radarbox.  Anyway, I think you can check to see which map and map colours Radarbox will use when it starts.  In the Windows registry:
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\General\MapColorpath is the default map colour file.
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\History\map1 is the default map.
Post by: drskeptical on February 16, 2009, 05:50:06 PM
Quote from: RodBearden on February 16, 2009, 04:18:56 PM
Oh well. Thats good news at least I cant blame Vista for this niggle.
I am still impressed, almost one year on now. I am currently tracking 171 flights with 439 msg / Sec.
Andy
