I suspect my ARB.........MAY NEED A REPAIR !
No signal .Blue lights flashing but no white flashing light ...
I suspect aerial connector..
Where is the best repair/service dept . in UK.. to get it checked over .
Ogilvie
Hi Ogilvie,
Try Waters and Stanton.
http://www.wsplc.com/acatalog/AirNav.html
Do remember that the RB has a TWO year guarantee, so unless you damaged it yourself, it should be repaired under the guarantee.
Thats good, but I bought mine on e-bay.no Guarentee..
However it has the serial number on it .....which might determine its age !
Ogilvie
Contact us direct, it still should be under warranty.
Thanks Airnav Support.I have contacted you direct .
Ogilvie . GM4VYU
Hello again !
Air nav Support asked me to contact them direct...................have done so 3 times, but no reply,! !
[ in connection with my faulty ARB.]
Is there a problem with server ??????????????
Ogilvie
Have a similar problem with my box but it works ok when I reset USB.
Only emailed yesterday but get the feeling I wont get a quick response.
Tried resetting usb...........but still only get Blue Light flashing once a second !
The antenna is OK ...............Also the RB sma is sound .......
even reloaded entire software.................but no joy.....................can see network traffic OK ,!
HELP PLEASE AIRNAV SUPPORT !!!!!!!!!
Where are you ???????????????
Quote from: cossarashill on March 03, 2009, 12:22:32 PM
I think that it is possible that you do not have the RadarBox driver installed correctly- have you watched this video on the AirNav support page?
http://www.airnavsystems.com/radarbox/video/Drivers.wmv
Can you see RadarBox in the USB properties window as shown here?
Hi Allocator,,,,,,,,Yes it says Radarbox in Device Manager......and that this device is working propery............with the most up to date Driver'''''''''''''''''''
Any other ideas.???
thanks
Ogilvie
Fair play to AirNav support who got back to me today. Not solved the problem but a response within 24hours is nice.
That,s OK.......I use the Airnav Support email link [since last Friday] ,but no reply.................I wonder if they have been going into thier Spam Box??
VERY STRANGE
Do you have a Ticket number cossarashill?
We always get back by 24hours. Usually much quicker.
My sincere appologies to you AirNav Support ! !
I found your mail in my servers "spam Box " DATED last Fri.27th.
I am now about to send it off to W&S well wrapped up !
will let you know what problem was .
thanks for your help .
Ogilvie GM4VYU.
