AirNav Radar => AirNav Radar Discussion => Topic started by: 9M-ISJ on March 04, 2009, 04:47:40 PM
Title: Loss of Range - Sorted
Post by: 9M-ISJ on March 04, 2009, 04:47:40 PM
Hello,
A few of you may recall that I recently had an almost total loss of range with my Radarbox, not sure if it was down to static or something else.
However the good news is that thanks to the VERY KIND help of Andre at AirNav I am now back up and fully running once more.
The level of customer service that I have had from AirNav goes above and beyond anything I could have hoped for and is very good to see in this day and age.
So, back to a screen full of plots at last! :-))
Title: Re: Loss of Range - Sorted
Post by: Johnn on March 04, 2009, 05:33:55 PM
Hi, What was the problem that gave you less range?
Post by: 9M-ISJ on March 04, 2009, 05:37:34 PM
No idea. Either a mystery burst of static (maybe from a hire car in the US, which was 'shocking' me everytime I got out of it) or through some other unknown issue
Paul
Post by: CoastGuardJon on March 04, 2009, 08:37:20 PM
Quote from: 9M-ISJ on March 04, 2009, 05:37:34 PM
Paul
Hi Paul, this is rather interesting.    Static can be induced in an antenna, by wind motion around it - especially hot, dry wind.   Was the antenna on the car roof when it was in motion and connected to the RB, or was it on the roof when car in motion, and then re-connected to RB?    I expect you can see where I'm going with this - was a static charge building up on the antenna and then discharged through the RB, the same as when you get out of the car, you get the shock...........
Post by: Allocator on March 04, 2009, 08:40:59 PM
Oh on, not the "static" issue again :-(
I thought that we'd done this one to death with all the other threads.
Post by: 9M-ISJ on March 04, 2009, 08:42:42 PM
No. Aerial was on its metal CD on the parcel shelf at the back of the car while we were in motion and was only stuck to the roof while the car was parked up.
Also we were in the deep South in Feb (North Carolina, South Carolina, Georgia, Miss, Tenn, and Ark) so not all that hot or dry!
But there is no getting away from the fact that the car kept 'shocking' me when I got out... Chevys**tbox that it was.
Post by: CoastGuardJon on March 04, 2009, 08:50:20 PM
Hi Allocator, are you having some bad days lately?;-)   I'm just interested in the exact circumstances that Paul's RB was subjected to prior to going U/S - something which could could be of benefit to all of us.    ESD is something which can knock out any electronics - on a very small scale - to lightning strike - to energy from solar flares taking out the most sophisticated satellites -  so I'm sorry if I'm boring you!
Hi Paul, thanks for the reply - that's that theory out the window.
Post by: Allocator on March 04, 2009, 09:01:16 PM
Hey, it was said tongue-in-cheek :-)
No, I'm no worse today than any other day, still a grumpy b****r
Besides, it's never been a static problem, its been that BN2T stooging around at FL100 zapping the boxes :-)
Post by: 9M-ISJ on March 04, 2009, 09:03:54 PM
No BN2T's in hill billy country.... lots of P3s, but they were all parked up at Greenville Center
Post by: E14 on March 04, 2009, 09:41:32 PM
Was it the same box or a replacement?
Post by: CoastGuardJon on March 04, 2009, 09:44:20 PM
Hi Allocator, no offence was taken as being intended - otherwise my reply would've been somewhat more caustic!     I think it's more likely birds from the other side doing for us (and the location map).    I'd better go steady or I'll be getting a Tarbat style writ..............    :-0
Post by: 9M-ISJ on March 04, 2009, 09:45:21 PM
Would seem to be a different unit, as I have had to change my user details and password.
I am just happy to be up and running again
Post by: mdobuk21 on March 04, 2009, 10:01:26 PM
hi guys, just to carry on the loss of range thread a little longer!!, sometimes i have no mes/sec at all showing, but when i touch the end of the antenna cable it suddenley boosts upto around 50-150 mes/sec! very strange and annoying. This is just with the standard antenna in leeds
cheers for any replys
Mark
Post by: Allocator on March 04, 2009, 10:02:34 PM
Quote from: CoastGuardJon on March 04, 2009, 09:44:20 PM
Yes, no problems there CoastGuardJon - just a bit of "banter" :-)
Post by: Canonjohns40D on March 04, 2009, 11:07:38 PM
Hi Allocator so it was the BN2Ts wot dun it then. Damn I was sure it was G-PSNI. LOL.
Post by: E14 on March 04, 2009, 11:47:03 PM
Quote from: mdobuk21 on March 04, 2009, 10:01:26 PM
Mark
When this happens do you loose the signal light? If you dont touch the aerial will the msgs come back eventually and how long does it take?
Post by: mdobuk21 on March 05, 2009, 12:13:53 AM
yeah loose the signal light, only get around four aircraft (depending on time of day) myflights only show around a quarter of what they should when i dont touch the antenna cable, as soon as touch the cable it shoots back up to over 30+ flights!
Post by: Fenris on March 05, 2009, 12:15:53 AM
Quote from: mdobuk21 on March 05, 2009, 12:13:53 AM
Sounds like the center conductor of the cable is not contacting the pin in the SMA plug, or less likely that the connector on the RB is not making contact with the plug's centre pin.
If it's either then a warranty return should fix it.
Post by: mdobuk21 on March 05, 2009, 10:11:09 AM
Cheers that makes a lot of sense, do I send the box back to the shop I got it from or is there somewhere else to send it?
