Antenna Wimo GP-1090 antenna amplifier LNA 1090A-TM cable RG-11 of 45 meters, Bias-T KU BT 271N. The antenna is on a roof direct radio visibility. Distance from the airport of 7 kilometers
Has changed USB port, the signal is!
What happens with the default antenna, did it work with that?
Does the RadarBox 2007 software confirm that RadarBox is connected?
Get rid of the amplifier, you do not need that with that antenna (I have it too) and good cable. Ronald
Fully agree on that, LiveAtc and Ron,
provided, the feeder cable does not exeed ~10 to 12 meter in lenght. Also take care of proper connectors.
Karl
