AirNav Radar => AirNav Radar Discussion => Topic started by: Johnn on March 10, 2009, 08:21:00 PM
Title: I have just installed a External Antenna and my Polar Diagram looks real small?
Post by: Johnn on March 10, 2009, 08:21:00 PM
I have had the box running for like 1hr 30 mins.
Does it need more time to grow?
Title: Re: I have just installed a External Antenna and my Polar Diagram looks real small?
Post by: RodBearden on March 10, 2009, 08:24:49 PM
John - remember that the polar diagram is set by the aircraft you receive which are broadcasting their position. As time goes by it will grow - wait until you've experienced a couple of traffic peaks - probably a full day's worth of reception - before you decide if you've got a problem.
Post by: viking9 on March 10, 2009, 08:26:25 PM
John,
Yes it does.
How high have got the antenna? Is it in the clear?
Post by: Johnn on March 10, 2009, 08:31:36 PM
Hi there, It is on a 12ft pole.  Its mostly clear except to the west. I looked back at the polar diagram from the twig antenna, and not a vast amount of difference yet. I will keep the radar box on for a few days and see what happens!.
Thanks John
Post by: viking9 on March 10, 2009, 08:37:08 PM
John,
As Rod said it will take a day or so.
Just a thought - you did fit the three radials, didn't you!
Post by: Johnn on March 10, 2009, 08:55:20 PM
Hello, Yes I Did!, What are they for?
Thanks John
Post by: CoastGuardJon on March 10, 2009, 09:10:18 PM
Hi John, it may be the case that the standard twig was picking up everything that was available, I must admit I've been very surprised by its excellent performance - it may well be that the Watson Radar Extender doesn't significantly improve my reception when I get it up, other than the fact it will be clear of the very limiting roof ridge to the East, and it's build for external use, which the standard twig isn't.    It could be that your physical location is the limiting factor - sorry if that may disappoint, but it may well be the case.   The 3 radials form the ground plane, the same as the CD size disc with the standard twig.    About 20 years ago, I built a discone out of thin stainless steel sheet, to the same dimensions as a Royal discone, the performance was hugely better, but couldn't be erected outside - interesting exercise though!
Post by: Johnn on March 11, 2009, 07:36:51 AM
Hi there! I have left it on over night and now I have a reasonable 360 view which did not happen on the twig antenna, I will leave a couple more days, but things are looking abit better now, compared to my last polar diagram.
Thanks for everyones help.
Post by: E14 on March 11, 2009, 10:19:15 AM
I put up the 5db RadarRama Antenna. Although my Polar diagram did not get that much bigger the flights at peak hours went from around 60 to 110.
Si in summary it did not help the overrall size of the diagram but did help the quality of data I was receiving.
