AirNav Radar => AirNav Radar Discussion => Topic started by: davjhedges on April 16, 2009, 06:08:03 PM
Title: worrying development.
Post by: davjhedges on April 16, 2009, 06:08:03 PM
i have owned an rb since early jan with no probs at all.on switching back on, after a two day break, i have suddenly gone from receiving,depending on the time of day,30,40,50+ adsb only contacts in my flights, to virtually none.my polar diagram is virtually non existent,and i only receive a contact if it is over the house.
i have changed the external aerial back to the original twig no improvement.
tried a different usb cable.
re- installed software.
problem remains .rb sma socket is firm,i can only conclude the fault is inside the rb.
considering the rb has suffered no trauma what so ever ,all the above is worrying.any help/advice would be much appreciated.thx david h.
Title: Re: worrying development.
Post by: bailey_uk on April 16, 2009, 07:54:53 PM
Ive recently had a similar problem, with exactly the same symptoms i.e only get a signal if the aircraft is over the house.
thread
http://www.airnavsystems.com/forum/index.php?topic=2398.0
James
Post by: AirNav Support on April 16, 2009, 08:27:53 PM
Hi David,
Sounds like something has happened, contact us via the ways in my signature and we will send you details on how to send it back to us.
Post by: davjhedges on April 17, 2009, 01:13:53 PM
thx James,and airnav support for your replies.i donot feel it is an aerial issue,more a hardware issue,so i am going thru official channels to resolve the problem hopefully.at least the network is ok so i can continue tracking for the moment.
regards,davidh.
Post by: viking9 on April 17, 2009, 02:23:20 PM
David,
I thought one could not receive network aircraft if the box was not functioning. Do you have lights flashing on the front of your RB? How many messages/sec are being shown at the bottom of the screen?
Post by: AirNav Support on April 17, 2009, 02:32:55 PM
If the software can see the RadarBox connected it allows the network, otherwise those people in areas where there is little traffic or none at night would be booted of the network and they wouldn't be pleased :)
Post by: viking9 on April 17, 2009, 02:37:37 PM
Booted off the Network! Poor choice of words from a commercial operation regarding customers.
Post by: AirNav Support on April 17, 2009, 03:04:20 PM
Thats why there is smiley face, it obviously doesn't happen.
Post by: viking9 on April 17, 2009, 03:11:04 PM
Sorry, don't normally see a smiley from you. I thought it was a typing error. :o) Still, my statement stands.
As for the user's problem - I'm sure we would all like to know what problem the box can develop after just sitting around for a while.
Post by: Eric on April 18, 2009, 12:42:31 PM
I seem to have the very same problem. Any ideas what could be the cause ?
Eric
20 miles S of EHGG
Post by: Allocator on April 18, 2009, 12:49:25 PM
Quote from: Eric on April 18, 2009, 12:42:31 PM
Eric
20 miles S of EHGG
Have you checked to make sure that the centre pin of the antenna plug has not been pushed back into the plug body?
Have you tried a different antenna?
Post by: reg on April 18, 2009, 01:37:02 PM
I also have had a similar problem for a long time now. Switched on one day and reception right down. Compared with an sbs-1 running along side. All fine there, so guessed it was a problem with the radarbox. It is nothing to do with antenna or usb connections. The Radarbox is the second one i have had. The first had a problem with the usb connection. Have yet to approach Airnav/dealer about repair or replacement.
Reg
Post by: Allocator on April 18, 2009, 02:01:12 PM
Quote from: reg on April 18, 2009, 01:37:02 PM
Reg
I'm surprised you haven't bothered to get a replacement.  I'd be onto this straight way, especially with the no-quibble guarantee that AirNav provide - as long as you haven't taken the box apart :-)
Post by: Eric on April 18, 2009, 03:40:51 PM
Quote from: Allocator on April 18, 2009, 12:49:25 PM
Eric
20 miles S of EHGG
The antenna plug looks as it should be. And yes, I have tried another antenna but with the same result.
Eric
20 miles S of EHGG
Post by: Allocator on April 18, 2009, 03:44:46 PM
Well, in that case I would contact Support direct at [email protected]
Post by: Eric on April 19, 2009, 01:52:26 PM
Actually, I bought the unit through a local agent. I have already contacted him and he agreed that he will replace the unit. Still, it's a mystery to me what could be the problem. When also looking at another post there are more people with this strange behaviour of the unit :-(
Eric
20 miles S of EHGG
Post by: Allocator on April 19, 2009, 04:30:41 PM
Doesn't really matter what the problem is, if you are getting a replacement box :-)
Post by: davjhedges on April 20, 2009, 12:06:57 PM
thx gentlemen,i feel it is a hardware problem within the decoding area of the rb,i still see the odd aircraft directly overhead,my external aerial  was pulling in adsb onlycontacts from the wash, to irish sea,to the channel.will keep you informed.regards,davidh.
Post by: Eric on April 24, 2009, 02:53:34 PM
Quote from: davjhedges on April 20, 2009, 12:06:57 PM
David,
I think you are on to something. I too only received some nearby adsb contacts with my own unit. I just connected another hardware unit which I now have on loan from the local agent, and WHOW: 185 airliner contacts up to 200 NM away ! My own unit is on its way to Airnav, I hope they find out what is wrong with it.
Eric
20 miles S of EHGG
Post by: ukpbz on April 24, 2009, 05:30:56 PM
I too am now seeing this problem.
I have emailed support ( Today ) and am awaiting a reply but why are there so many getting similar faults all of a sudden?
Anyway, looking forward to getting it fixed now Viking9 has shown me how to use it properly :-)
Post by: davjhedges on April 25, 2009, 07:23:24 PM
Gentlemen, I believe there  to be a fault in the front end of the rb,eg, where it receives the data from the antenna,i am parcelling it up this weekend to send it back for service/ repair. Please see my  polar diagrams, the most recent one is rather truncated I think you will agree.
sincerely,davidh.
[img=http://img139.imageshack.us/img139/2302/house005.jpg] (http://img139.imageshack.us/my.php?image=house005.jpg)
[img=http://img219.imageshack.us/img219/6969/49288538.jpg] (http://img219.imageshack.us/my.php?image=49288538.jpg)
Post by: CoastGuardJon on April 25, 2009, 08:53:18 PM
Hi David, I've found that range and reception is extremely weather dependent - high pressure and clear skies - very good range, misty, cloudy, rainy low pressure - range much diminished.    Anyone else find this?    I thought mine was going deaf, but then it started going berserk again - could it be routing is drastically altered by weather patterns?
Post by: ukpbz on April 25, 2009, 09:12:00 PM
Hi CoastGuardJon,
My problem is certainly not weather initiated> I was at an airfield reently with another user in the car next to me. I was seeing 12 aircraft, he was seeing numbers in the hundreds.
We had exactley the same kit.
