Probably a non-starter - but is there any way of altering the column sequence in"MyFlights" so that (for instance) it would show (instead of the default)....?
Changed Tracked Reg'n ModeS Flight ID, Squawk...then the rest of the info.
There isn't but this has been noted down for the next version.
That would be good - It's a pain having fancy flags ,Logos and silhouettes where the factual info would be far more use in the first few columns...leave the "pretty" stuff to the far right where it can be hidden out of the way.
Quote from: daveg4otu on April 25, 2009, 08:19:12 PM
If you dont want the "pretty stuff" you can de-select it in Preferances.
Just untick the info you dont want to see and press apply. It then all shuffles across so you can narrow the Myflightss box down and see more screen.
HTH Cheers John
Brilliant - that's a big help ...Thanks.
