I leave my PC on 24/7 (The tree-huggers will love me) but don't leave the Radarbox on.To ensure the network gets the additional coverage I thought about leaving the radarbox on.
One question though what is the typical bandwidth useage of Radarbox?
I have a reasonable download allowance every month,but am quite a heavy user.
I would disable the download pictures if that would make a difference.
Brimon
I would imagine as the data is in a text format very little, as you have turned of the photo. They tend to be the real file size grabbers.
The pictures are only thumbnails. I've just looked at my photos folder and it's only 100MB. That's after more than 12 months of use so on a day to day basis the photo downloads are hardly likely to make a dent in usage.
Chris
Yes absolutely right, I assumed they would be bigger that that, so on the whole there is not a great amount being downloaded?
Thanks for the info all.In the interests of fellow networkers I will try leaving it on & see how I get on.
With all the 'unlimited downloads???' that the broadband companies offer, surely its not a problem :-)
I suppose you could check the network overhead reasonably accurately using DU Meter with just the RB program running at the time. Here, the cable modem lights flicker for a second every 30 secs as the network updates. I'd hazard a guess that the overall usage in a 24 hour period is negligible in the great scheme of things.
Unlimited downloads provided that they're during a time when most people are in bed ;)
You have time to sleep with all this activity going on? ;-)
Bandwidth was discussed last year, and my conclusion was that a 24x7 PC running RB will consume about 18GB per month.
See http://www.airnavsystems.com/forum/index.php?topic=507.msg9105#msg9105
Thanks tarbat. Obviously,like everyone here probably, I would like to give network users the benefit of additional cover by leaving it on 24/7 but ,if the figures are right, 18GB per month is a hefty hit on bandwidth.
I will monitor it for a couple of days & decide.In the meantime thanks again.
Let me just confirm, you can still share data with having the network download switched off.
Sharing bandwith depends on the amount of aircraft you have but at its max it won't upload anything more than 800mb per month in busy conditions.
Be wary of turning off photos - as I recall there is an issue with turning off the downloading photos option affecting receipt of network traffic. Maybe Airnav could confirm that? I gather it's a known issue and is one of the fixes in the next version.
Have a look at: http://www.airnavsystems.com/forum/index.php?topic=1908.msg15302#msg15302
DC
It is fixed :) Look out for it soon.
Quote from: Brimon on May 12, 2009, 07:43:57 AMThanks tarbat. Obviously,like everyone here probably, I would like to give network users the benefit of additional cover by leaving it on 24/7 but ,if the figures are right, 18GB per month is a hefty hit on bandwidth.
That 18GB per month was for DOWNLOAD and UPLOAD. I guess the UPLOAD would be a lot less, but would really depend on the number of aircraft being uploaded to the Airnav servers. I'm in a very light traffic area, so my upload is probably small.
Still seems a large download/month.
Where is most of the data coming from?
Quote from: malc41 on May 12, 2009, 09:26:43 AM
Its the download of >1000 aircraft positions/etc. every 30 seconds.
But that is only if you are connected to the network and downloading info. I think the origional message was refering to supplying info to the network?
Quote from: malc41 on May 12, 2009, 09:44:54 AM
malc, as you know I am new to the Radarbox & as such will ask stoopid questions:).
If I left the Radarbox on with the network connected, I was under the impression that I would have no option but to upload & download (with the exception of pictures) everything.Am I wrong,can I turn off other aspects?
You can turn off the network download, and you will still be uploading your local aircraft to the Airnav network.
Further observations using DU meter for the past hour. The PC is just running RB and an instance of Outlook Web Access occasionally polling my work mailbox.
Hourly total is 18.6MB with approx 1100 network flights at present
Extrapolate for the day: 446MB
For the week: 3.1GB
And the month: 12.5GB
It's worth noting that as the number of network flights drops off considerably during the late evening and wee, small hours you could treat that estimate as worst case scenario.
Since reading this I have run a monitoring app(BW Monitor) for 2 hours....
ANRB is running
Hardware traffic only .
Average "My Flights" 55-65 showing
Photos turned OFF.
Winsend is running uploading to Libhomeradar.
IE is running one or two pages.
The figures....
2 hours
Downstream was 39.89MB
Upstream 6.01MB
Taking that and turning it into 24hrs/30days per month and you get a ballpark figure of 14GB Down.....
But...
The traffic levels(and consequently the up/down levels ) are generally going to be far less for the period from 8PM- 8AM(local)...so IMO a figure (under the conditions above) of 10-12 GBs would probably cover it.
Location is Torquay.
5miles N of BHD.
EDIT: I run twin monitors....hence IE in use at the same time.
Still a fair slice of your bandwidth if you have a restricted to monthly limits
Quote from: malc41 on May 12, 2009, 12:02:42 PMStill a fair slice of your bandwidth if you have a restricted to monthly limits
In which case, please support my feature request to have the option to limit downloads to just those aircraft that would be visible on the current map view. See http://www.airnavsystems.com/forum/index.php?topic=507
No, a test version is already out to a few members. Please read the sticky as well regarding the version on the forum.
We can confirm that the upload is 5% of the download rates - the upload can be easily maintained with a dial-up connection.
The software has a way of predicting which messages are relevant for upload: for example an aircraft can transmit 60 ADS-B message per minute. The software will only upload one with the relevant data and when it finds the data useful.
