AirNav Radar => AirNav Radar Screenshots => Topic started by: t1mb0 on May 25, 2009, 07:06:44 PM
Title: New user in Hampshire
Post by: t1mb0 on May 25, 2009, 07:06:44 PM
currently using a homebrew antenna in the loft on the end of about 10m coax though.
ground level elevation is 42m.
Currently planning to drastically shorten the coax before resorting to a) another design, or b) a commercially available antenna.
Impressed with the box.
Title: Re: New user in Hampshire
Post by: malc41 on May 26, 2009, 07:29:28 PM
t1mb0
Homebrew seems to be working nicely for you
Welcome to the forum
Post by: t1mb0 on May 28, 2009, 11:50:45 AM
Thanks, got the box in the loft now, with the help of 20m USB extension which works well. Antenna feed now < 1m.
All 'hardwired' to my home office PC, then I use my wireless laptop to roam around the house/garden to RDP to the main PC and run the application.
My loft has a couple of fluorescent lights, and I have noticed without fail that turning these on causes the connection to the hardware from the PC to drop, with only the green light remaining on. Disconnecting/reconnecting the USB gets it talking again.
Perhaps this particular issue is for discussion in another thread.
Post by: t1mb0 on May 30, 2009, 03:28:50 PM
OK, so now I'm still on my homebrew in the loft, but with the ELAD 1090 pre-amp.
A bit of a difference, my nominal count went from abot 40 max to 140.
Max range just over 280 miles.
Next post will be a screenshot after mounting the antenna above the eaves.
Post by: malc41 on June 01, 2009, 12:42:34 PM
Looking even better, hope that once you get the aerial higher the range to the north will increase
Post by: t1mb0 on June 23, 2009, 05:53:30 PM
OK, as promised here is the polar diagram with the antenna clear of the chimney outside.
I am quite happy with the coverage, if you're wondering, there is gently hilly terrain to the north and north east of me.
Post by: t1mb0 on June 23, 2009, 05:57:08 PM
ahh perhaps its a feature of v3.0 when I tried to view that gif I don't see the polar diagram extent, I will see you later
Post by: t1mb0 on June 24, 2009, 04:21:44 PM
here it is
homemade antenna with ELAD 1090 pre amp
