Hey, hope someone can help me with this, this is my first post on the forum and I was wondering if you could use a USB to Ethernet adapter on a network, I have my antenna on the roof and I would like to set up a network for my entire household and would like to simply connect the radarbox to the network and pick it up over every computer on the network, not at the same time obviously but simply so that whichever computer I choose to connect to the service through I can pick it up. Is this possible?
Many thanks
Users have reported success with logmein.
http://www.airnavsystems.com/forum/index.php?topic=2500.0 (http://www.airnavsystems.com/forum/index.php?topic=2500.0)
Quote from: catman on May 28, 2009, 01:18:29 PM
No - AFAIK the RadarBox software won't run unless it finds the hardware attached to the local PC via USB.
Many thanks for the fast replies,
So if I used a USB to ethernet adapter and ran the ethernet to my computer then it would work? but through a switch or something it does not? Judging from the responses on other threads? No possible way of making it a network device and it showing on the computer? And for this USB to ethernet adaptor what one would people recommend? If that works?
Thanks again
Quote from: catman on May 28, 2009, 07:42:53 PM
Read my reply again. There is no option in the RadarBox software which allows you to specify a TCP/IP address for the hardware.
The interface has to be USB (which doesn't rule out using a USB <-> Ethernet <-> USB extender).
Quote from: DaveReid on May 28, 2009, 11:01:54 PMThe interface has to be USB (which doesn't rule out using a USB <-> Ethernet <-> USB extender).
I had some limited success using USB over Ethernet with the Radarbox, using Eltima's USB to Ethernet Connector solution. See previous discussion at http://www.airnavsystems.com/forum/index.php?topic=1246.msg16278#msg16278
I am using a remote PC in my house for better antenna location.
I run the great free tool ULTRAVNC. I can get full access to my RadarBox computer over my local netowrk or from "outside" over the internet.
Great free tool. No need for any service for logining in.
Thanks again for the replies, so with this ULTRAVNC, I'm presuming I'd need say a low power computer to just sit on the network with the radarbox plugged in to access it over the network?
This seems to sound like the only possibility.
Many thanks for all the replies though
I am running my RadarBox on an old P4 2Ghz computer with 1GB RAM and ULTRAVNC.
This computer has only power and network connections
Works great
Thanks for confirming that, I shall look into it!
