I'm seeing an awful lot of network flights with NA as the Status, and they're not on the map. What's that about?
Thats a new one, not noticed that before.
I'm seeing lots of NA in the network list as well.
It's quite a problem!
(http://www.rbearden.toucansurf.com/NA.gif)
NA means not available, flights which status is unknown. You will see lots of these flights on ground.
I don't remember seeing so many NA aircraft in previous versions. Is there some other factor causing this?
(http://farm4.static.flickr.com/3455/3712431244_b7270cee3b_t.jpg) (http://www.flickr.com/photos/tarbat/3712431244/sizes/o/)
There are an awful lot of NA's at the moment.
Quote from: AirNav Development on July 12, 2009, 01:31:25 AM
Dev - no we won't - because they don't show position!
I'm a bit confused by this - it used to be that all flights on the network (except timeouts) showed position - by definition, they only got onto the network if they did show position.
These NA flights are confusing the issue. Is this change a genuine enhancement or a bug?
Even stranger, some of the NA aircraft hav no position, but do have a Dist(NM) value. If Radarbox doesn't know the position of the aircraft, how can it know the Distance from home?
I've noticed that the NA aircraft don't have Altitude or GS.
I don't know about you chaps, but I find that the NA aircraft are completely pointless - all RB's telling us is that these aircraft exist, and are probably powered-up.
Why clog up the network and our grids with them?
We will explain what happens: with the new network flight routines to avoid flights being concentrated at runway ends time-outed we had to introduce several time-out routines. These cause that some NW flights change to a different status. There is nothing we can do about the... unless change the flight status routine so it returns a different Status, not NA but...?
Maybe rename NA to TimedOut? And ensure that these time-out aircraft still display their last known altitude in the aircraft list.
As I type this, there are 1203 aircraft on the network, and 335 of them are NA. That's over a quarter of them!
If we can't tell where they are, I would rather they weren't there at all.
Corrected. NA flights will not be shown on the Network grid.
I take it you mean noT - not noW!
Thanks, Dev!
Corrected.
