all,
i have a problem with putting new routes info in to data base explorer, i put them in ,but it doesnt come up on the screen, is this a known bug? anybody got any suggestions,
thanks davec
Do you include the date and time in the format that the other entries use?
yes and no, i did it with two entries ,the rest i didn,t
davec
It will only pick up the route the next time an aircraft using the flight number is recieved. To test it put in the route untick Process Hardware Flights and then retick Hardware flights and it should then be picked up.
If the NV field, in Route database is pink just type a character into the field and then delete this character to turn the field white and it should then work
Hope this helps
Stewart
HI bearcat,
i think thats solved it thanks a mill
regards davec
hi,bearcat
after loading in awe etc into the dadabase explorer, it still isnt coming on the screen,i did everything right so this must be a bug it was working last night
i have given up
regards davec
