Is it as simple as putting a registration number on the list and ticking the box? I do not seem to be able to make it work. I have Play a sound ticked and a wav file selected.
On V.3B
J.
Quote from: Jeremy on July 18, 2009, 05:05:21 PM
On V.3B
J.
Yes it is.
This is my Alert setup at the moment.
I do not see tht file in the sounds field when I browse. Just 2009 not v.3B. I have found a windows wave file.
What alert is the 7000 and 7001?
J.
Quote from: Jeremy on July 18, 2009, 07:43:10 PM
J.
See this link for the UK SSR code allocation:
http://www.kinetic-avionics.co.uk/forums/viewtopic.php?t=2115&highlight=ssr
You can use any wav file as the alert sound. The file provided with RB is D005.wav whic is in the /Data directory.
Hi all
I have been reviewing my alerts problem with v3 beta.
In V2 I had a 1000+ registration alerts which worked afaik flawlessly. I had issues with wild cards in the hexcode field not always alerting. As a number cruncher I need full registrations rather than wild cards in my alerts.
However, with version 3 I have noticed after the app has been running an extended period of time the number of reg alerts I get reduces until I virtually get none. The only way to get around this is to stop and start the app. It seems to me that a buffer/memory space gets filled and is only gets cleared when closing the app.
I try and avoid doing this too often as RB takes a while to startup.
Hopefully this will get fixed in later releases of the beta.
Hope this helps
Graham
