AirNav Radar => AirNav Radar Discussion => Topic started by: lambertw on July 21, 2009, 09:20:55 AM
Title: Mode S
Post by: lambertw on July 21, 2009, 09:20:55 AM
Is it possible to filter out non ADS-B aircraft so that you can only see these on the information screen and not have the ADS-B aircraft showing.
Title: Re: Mode S
Post by: nortonbeak on July 21, 2009, 09:26:48 AM
Quote from: lambertw on July 21, 2009, 09:20:55 AM
If you mean "not have the non-ADSB aircraft showing", then press the ADSB only button.
Title: Re: Mode S
Post by: bratters on July 21, 2009, 10:09:36 AM
Quote from: nortonbeak on July 21, 2009, 09:26:48 AM
Excuse my ignorance but where is the ADSB only button located?
Title: Re: Mode S
Post by: RodBearden on July 21, 2009, 10:53:15 AM
Bratters - it's above the grid - if you only have a narrow grid you may have to resize it as it may be being hidden by your map:
Title: Re: Mode S
Post by: DaveReid on July 21, 2009, 11:04:42 AM
Quote from: RodBearden on July 21, 2009, 10:53:15 AM
And of course the button only appears on the MyFlights page as Network Flights are all ADS-B
Title: Re: Mode S
Post by: Terre on July 21, 2009, 11:05:42 AM
You'll find the filter button 'ADSB only' in the quick filter section of 'MyFlights' in the Interface, just above the grid.
(http://www.airnavsystems.com/forum/index.php?action=dlattach;topic=3116.0;attach=4375)
However, as you said you want to filter out non ADS-B aircraft, this quick filter will not work. You might want to follow Allocator's suggestion to activate a filter using "Latitude = 0", see his post:
http://www.airnavsystems.com/forum/index.php?topic=480.msg3595#msg3595 (http://www.airnavsystems.com/forum/index.php?topic=480.msg3595#msg3595)
Title: Re: Mode S
Post by: bratters on July 21, 2009, 11:11:47 AM
Cheers fellas.
Title: Re: Mode S
Post by: lambertw on July 21, 2009, 11:23:47 AM
Got it sorted now, thank you all.
Title: Re: Mode S
Post by: malc41 on July 21, 2009, 07:45:54 PM
This is a good point as how many people miss these buttons because the map covers them up?
Title: Re: Mode S
Post by: Jeremy on July 21, 2009, 08:30:07 PM
How do you bring that row of buttons to the front? The map window seems to be fixed.
J.
Title: Re: Mode S
Post by: Allocator on July 21, 2009, 08:37:27 PM
Quote from: Jeremy on July 21, 2009, 08:30:07 PM
J.
You can drag the divider between the map and the lists.  Just put your mouse pointer over the line and when it changes to a double headed arrow, hold the left mouse button down and drag left/right as required.
Title: Re: Mode S
Post by: Jeremy on July 21, 2009, 08:45:36 PM
Found it but  it is a slow task when my cpu is so active. I do not have that button. The last one is Show All.
J.
Title: Re: Mode S
Post by: Allocator on July 21, 2009, 08:49:27 PM
Quote from: Jeremy on July 21, 2009, 08:45:36 PM
J.
The ADS-B Only button ONLY appears in the MyFlights tab, as ALL the aircraft in the Network tab ARE ADS-B.
Title: Re: Mode S
Post by: Jeremy on July 21, 2009, 08:51:25 PM
Thank you. A fountain of all knowledge as always.
J.
Title: Re: Mode S
Post by: DaveReid on July 21, 2009, 10:31:39 PM
Quote from: Allocator on July 21, 2009, 08:49:27 PMThe ADS-B Only button ONLY appears in the MyFlights tab, as ALL the aircraft in the Network tab ARE ADS-B.
I could swear I've read that somewhere else recently  :-)
Title: Re: Mode S
Post by: Allocator on July 21, 2009, 10:33:28 PM
It was more polite than saying read back through the thread :-)
Title: Re: Mode S
Post by: CoastGuardJon on July 21, 2009, 10:36:22 PM
Deja Vu or a miracle..............................?
Title: Re: Mode S
Post by: Allocator on July 21, 2009, 10:38:42 PM
Quote from: CoastGuardJon on July 21, 2009, 10:36:22 PM
Always wanted one of those - small French car with a big sunroof, don't think that they make them any more!
Title: Re: Mode S
Post by: malc41 on July 22, 2009, 09:22:35 AM
Try Ebay? ;-)
