We have great news for our ShipTrax project.
The final hardware is being tested with successful results.
If it passes all the tests mass production will start.
Quote from: AirNav Development on July 22, 2009, 03:12:43 AM
Any clues as to the specification ? I am about to buy the Comar AIS-2-USB.
Cheers,
Peter
Dual receiver (bot AIS channels at the same time), ethernet, USB and serial output and free ShipTrax software. (much better than any of the current receivers... :-) )
And the price is?
We are not yet sure about it but will be similar to Comar AIS-2-USB.
Hi There, Will Ship Trax Work With A 1090Mhz Antenna, For E.g. The Antenna I Use For My Radar, ?
Thank You
Quote from: Johnn on July 22, 2009, 04:58:35 PM
Thank You
Nope, different frequencies altogether:
The AIS transponder normally works in an autonomous and continuous mode, regardless of whether it is operating in the open seas or coastal or inland areas. Transmissions are found on two frequencies, VHF maritime channels 87B (161.975 MHz) and 88B (162.025 MHz) and use 9600 bit/s Gaussian minimum shift keying (GMSK) modulation over 25 or 12.5 kHz channels using the High-level Data Link Control (HDLC) packet protocol. Although only one radio channel is necessary, each station transmits and receives over two radio channels to avoid interference problems, and to allow channels to be shifted without communications loss from other ships. The system provides for automatic contention resolution between itself and other stations, and communications integrity is maintained even in overload situations.
http://en.wikipedia.org/wiki/Automatic_Identification_System
I would be interested in ShipTrax but living where I do slap bang in the middle of the country could I expect to see anything at all?
http://www.glyn.me/radarbox
AirNav (or MarineNav :-) will the ShipTrax software have a network tab similar to that in RB?
If so I am guessing I will have to buy the hardware and have it connected as a dongle just to receive network data?
Thanks & regards,
-=Glyn=-
ShipTrax is a virtual copy/paste of RadarBox but for ships so you will have the network tab and mylog too. It is very addictive and our team spends hours playing with it. You will also be able to connect to remote tcp/ip locations sharing AIS data. The software looks great. The hardware too but not yet finished.
Yeah but do you think I might be able to pick up any ships live from my inland location?
And if I can't then can I just purchase the software only and connect to the network or is it bundled with the hardware acting like a dongle as with the RB?
Can you expand a little more on the ethernet function - is it directly addressable via TCP/IP from the network instead of USB for example?
Oh and tell your team to stop spending hours playing with it and get back to work on v3.0! :-)
Thanks & regards,
-=Glyn=-
Glyn, Are you real high up with your location, if so wouldent you be able to get a good range?
I am in a dip, though only a mile from the sea.
Hi John,
Well I'm in North Oxfordshire @ 460 feet amsl and on a hill to boot but am way inland as you will see if you click on the link to my RB website a few posts up.
Not sure how much traffic I might expect to see from here :-(
Thanks & regards,
-=Glyn=-
Hi Glyn,
Well, This Is -What I Did To Figure Out How Much Range I Would Get With The Ship Trax, Correct Me If Im Wrong, I Just Looked -At My Radar Polar Diagram, And Looked At The Sea Coverage I Would Be Getting. If That Makes Sence?.
Hope That Made Sence.
I live in Bicester Oxon I use shipplotter and either an ais box or my icom and when the skip, ducting, or other atmospherics are right I somtimes get ais signals from much further than line off site obviously i can go weeks with nothing but I check it out sometimes and suprise there it is.
I did recieve what was obviously a small boat on the thames near Oxford for a few days last year.
Quote from: Johnn on July 24, 2009, 11:58:36 AM
Hi Glyn,
Hi John
I don't think it does actually make sense unfortunately. If ShipTrax works on line of sight like RadarBox does then your polar diagram for RadarBox would not be relevant for ShipTrax. Bear in mind that aircraft your RadarBox is picking up could be at 36'000 feet and therefore in line of sightm whilst a ship in the same position (at sea level of course) would be well over the horizon.
This product is months late.
Any update please or has it been cancelled?
Its not cancelled, its being tested at the moment.
If your hardware is better than Chinese Smart Radio SR-162, sounds good. We will see what AIS community say....
Any update to the July update on the hardware?
How about a realistic ETA this time?
Quote from: VK2GEL on October 22, 2009, 09:05:45 AM
hi VK2GEL
Remember the saying Rome was not build in a day, i am looking forward to the new
product my self, but someone has to develop it first, the screen shoots looks great
http://www.airnavsystems.com/forum/index.php?topic=3577.0
from pat
They are not screenshots of the hardware.
We have been told April, then July, it's nearly November now!
I need another receiver and want to buy an Airnav one.
Quote from: VK2GEL on October 23, 2009, 02:53:42 AM
hi VK2GEL.
Do not know what your expecting, but i guess it will be like the airnav box
tune to 161.975mhz and 162.025mhz fm.
from pat
Quote from: AirNav Development on July 22, 2009, 12:30:02 PM
I read this and wonder, "Why is that RadarBox also has an ethernet port?"
I read this and wonder: there are a lot of good dedicated AIS receivers on the market, why don't concentrate on good software?
I even more wonder why AN mentions that their AIS receiver is much better??
But okay, okay they put a :-) on it!
