AirNav Radar => AirNav Radar Discussion => Topic started by: EK01 on July 23, 2009, 08:35:33 PM
Title: Network
Post by: EK01 on July 23, 2009, 08:35:33 PM
Anyone else experiencing problems with the network tonight. Info seems to be very erratic. At the moment nothing is coming through.
Title: Re: Network
Post by: CAM on July 23, 2009, 08:37:57 PM
Same here, very erratic
Title: Re: Network
Post by: AirNav Support on July 23, 2009, 08:43:42 PM
We are investigating this issue. Can you confirm also which version you are using?
Title: Re: Network
Post by: John Racars on July 23, 2009, 09:01:48 PM
Hi Support and All,
Same here as well after installing V 3.01 Beta....
Title: Re: Network
Post by: radarspotter10 on July 23, 2009, 09:08:52 PM
Quote from: John Racars on July 23, 2009, 09:01:48 PM
Hi Support and All,
HI
same here happen after installing v 3.01 beta
from pat n.ireland
Title: Re: Network
Post by: Canonjohns40D on July 23, 2009, 09:12:47 PM
Hi I also have noted this, again after the installation ofv3.01 beta.
Title: Re: Network
Post by: John Racars on July 24, 2009, 07:06:33 AM
Hi Support and All,
At this moment the Network is stable again with me. I have running it for more then a half-our without any problem.
Title: Re: Network
Post by: 54901 - Jim on July 24, 2009, 12:30:00 PM
My network flight total showed (0) for a short while, just a few minutes ago.
Jim
Oshkosh
(Using 3.01 on Vista)
Title: Re: Network
Post by: EK01 on July 24, 2009, 12:39:19 PM
At the moment seems to be ok. Using Vista.
Title: Re: Network
Post by: AirNav Support on July 24, 2009, 12:57:36 PM
We have worked out whats happening:
The network timeouts in Version 3 are now strict. So if you fail to get a download update from the server or takes it longer than imagined you will end up in the network traffic timing out and hence changes in the numbers.
In future version we will increase the timeout so a longer download or failed download doesn't result in removing of network aircraft untill after a longer period of time.
Title: Re: Network
Post by: EK01 on July 24, 2009, 01:10:46 PM
Thanks Airnav,
Title: Re: Network
Post by: Canonjohns40D on July 25, 2009, 08:45:06 AM
Hi Airnav and thanks for the info. Just now 4 network flights only showing on my box.
Title: Re: Network
Post by: pcochrane12 on July 25, 2009, 08:52:11 AM
networks in and out like a fiddlers elbow this morning currently 1 flight showing
cheers paul
Title: Re: Network
Post by: lambertw on July 25, 2009, 08:55:11 AM
Ya, same here must be network problem.
Title: Re: Network
Post by: tarbat on July 25, 2009, 08:57:15 AM
Its a timeout problem in the v3.01 beta, which Airnav have said will be fixed in the next beta release.
You might want to revert to the previous version if the network is important to you.
Quote from: AirNav Development on July 24, 2009, 01:57:50 AM
The reason for this is easy to explain: network flight position expires if not updated within 30 seconds. Data is downloaded form the network in 30 seconds too. So if there is a delay on an internet data download, lat/longs will be cleared and as the network grid (as per a request received here) only shows flights with lat/long...
In resume we will change the timeout to 60 secs instead of 30.
Title: Re: Network
Post by: lambertw on July 25, 2009, 09:27:42 AM
I didn,t notice this problem yesterday.
Title: Re: Network
Post by: Hosch on July 25, 2009, 10:14:37 AM
Airnav, I think we need a patch soon for the network to work correct again.
Greetings from Luxembourg
Title: Re: Network
Post by: lambertw on July 25, 2009, 10:26:18 AM
Network totally unusable at moment.
Title: Re: Network
Post by: jasper37 on July 25, 2009, 10:45:10 AM
same problems here too in the UK
Title: Re: Network
Post by: Terry on July 25, 2009, 10:49:30 AM
Hi there,
             Network down and i`m using version 3.0 beta,very strange?It has been fine until version 3.1 beta release?
Title: Re: Network
Post by: tarbat on July 25, 2009, 10:50:37 AM
If the network is important to you, then just revert to v3.0 beta.
Title: Re: Network
Post by: AirNav Support on July 25, 2009, 11:53:36 AM
Guys Please read our comment about Version rather than posting about what you tihnk is happening with the network:
Title: Re: Network
Post by: carp777 on July 25, 2009, 12:02:47 PM
i have not updated to v3.01 i am still running version but i am not getting any network flights at all
                            Bryn
Title: Re: Network
Post by: Terry on July 25, 2009, 12:04:12 PM
Hi Tarbat,
             I am using 3.0 Beta version,still no network flights,after i downloaded 3.1 Beta version,"bong" network flights went on and off,so i returned to Beta 3.0,but i`ve just got a yellow network connected box and 0 network flights.How strange,disregard this post as the network has just returned.
     Best Regards Terry.
Title: Re: Network
Post by: AirNav Support on July 25, 2009, 12:04:27 PM
The network had some quick maintenance to see if we can improve the speed. It should be running now.
Title: Re: Network
Post by: Terry on July 25, 2009, 12:07:35 PM
Thanks AirNav,
                      Network up and running,100% on the ball as usual.
        Regards Terry.
Title: Re: Network
Post by: carp777 on July 25, 2009, 12:41:52 PM
network off again
       Bryn
Title: Re: Network
Post by: Terry on July 25, 2009, 01:15:38 PM
Yep,
      Same here Bryn,think i`ll turn it off and try again later in the day.
   Regards Terry.
Title: Re: Network
Post by: itestoo on July 25, 2009, 01:17:32 PM
Network down here in france too, with 3.0 and 3.01 version
Good luck to find what happen's
Regard's
Laurent
www.radarvirtuel.com
Title: Re: Network
Post by: sterigia on July 25, 2009, 01:31:36 PM
network on and off for me using beta 3.01 and a vista machine, location sardinia
frank
Title: Re: Network
Post by: AirNav Support on July 25, 2009, 01:35:57 PM
We are investigating, Please bear with us.
Title: Re: Network
Post by: EK01 on July 25, 2009, 01:39:32 PM
Network is off again. I certainly do not want to revert to version 3 beta as this was the version which had huge problems with showing my flights traffic unless you zoomed in and out. An even bigger pain !.
Edit: Appears to be back on again.
Title: Re: Network
Post by: AirNav Support on July 25, 2009, 01:50:03 PM
This issue at the moment is not due to versions, its the server playing up. Any version you use you have the same issue if the server is misbehaving.
Title: Re: Network
Post by: EK01 on July 25, 2009, 02:17:03 PM
Airnav,
Thanks for the clarification.
Cheers,
Title: Re: Network
Post by: velcrohead on July 25, 2009, 02:50:23 PM
Aha, I was just about to ask about the network and saw this post.
Title: Re: Network
Post by: EK01 on July 25, 2009, 03:24:45 PM
Velcrohead,
It's like the rest of us - overworked and under pressure i.e. knackered !
Title: Re: Network
Post by: velcrohead on July 25, 2009, 03:26:54 PM
Quote from: EK01 on July 25, 2009, 03:24:45 PM
Velcrohead,
Ha ha, ok, I know the feeling.
Title: Re: Network
Post by: RBO2009 on July 25, 2009, 03:49:27 PM
Hi Everyone,
Same here in Brussels for me. Since this morning : Network(0)...
Title: Re: Network
Post by: CoastGuardJon on July 25, 2009, 09:28:09 PM
Quote from: tarbat on July 25, 2009, 08:57:15 AM
Another Beta release, we're being spoiled rotten!  :-)
Almost as frequent as SBS new releases!
Title: Re: Network
Post by: AirNav Development on July 25, 2009, 10:01:51 PM
Today's network problems have nothing to do with V3.01. They are server related. :-)
Title: Re: Network
Post by: abrad41 on July 26, 2009, 04:16:40 PM
I am having network problems today.
Its seems to be drifting in and out and very unstable.
Andy
Title: Re: Network
Post by: carp777 on July 26, 2009, 04:28:20 PM
Network down again?
                      Bryn
Title: Re: Network
Post by: colinhall on July 26, 2009, 05:20:45 PM
Just put ANRB on to see if anything diferent about and the network down again just like this morning. Colin.
Title: Re: Network
Post by: AirNav Support on July 26, 2009, 05:45:44 PM
The network is online, its suffering minor outages of a minute or so then coming back. Its still the issue of yesterday but otherwie it has not been down all day as you suggest.
Title: Re: Network
Post by: sterigia on July 26, 2009, 06:42:20 PM
you are right on that, support. mine has been on and off every 20 seconds and it is still like that so it' more or less useless. i dont' think it's a minor outage. then again it depends on what you think is a minor outage.
cheers, hope it gets fixed soon
frank, sardnia
Title: Re: Network
Post by: John Racars on July 26, 2009, 06:46:18 PM
I am verry sorry to say, but at this moment the Network stays verry unstable with me. I checked out my internet connections; everything is allright. I started listening at 20:25 (LT) and stoped this at 20:40. In between the network goes on and off....
Title: Re: Network
Post by: DVDW on July 26, 2009, 06:55:01 PM
Same problems over here. The network is drifting in en out and when i have network connection the network grid jumps from 650 to 3 or even less... However, everything else is working perfect and of course, this version is still a beta.
Greetz,
Dirk.
Title: Re: Network
Post by: AirNav Support on July 26, 2009, 07:03:28 PM
Ok this needs some explaniation as some users are getting confsued. Please read this before posting
There are 2 issues going on:
1.) Server Stopping
We are working on the server to try and rectfy this issue. This is causing the server to drop out occasionaly for a minute and then come back.
2.) Beta 3.01
The beta has an issue whereby if your internet is slow or our server is under load it may take extra time to download and after a spefic time it will timeout the network flights meaning you will see a large drop in network flights (but not zero) and it should then return to normal once it download in time again.
Title: Re: Network
Post by: sterigia on July 26, 2009, 07:43:12 PM
no it returns to zero, sometimes 3-4 flights.my internet connection is not slow, 10 mbits\sec.  the timeout issue is too stringent as i have noted less network flights than usual when they are showing so surely other users have the same problem
cheers,
frank
ps even now as i write 391 network flights-255-614-623-0-145- etc
Title: Re: Network
Post by: John Racars on July 26, 2009, 07:57:47 PM
Quote from: AirNav Support on July 26, 2009, 07:03:28 PM
OK Support, clear to me.
I understand that this means that the network never will work with me like before the launch of the recent Beta's.
I am sorry for that if that is so. I switch off the network from now on because I can not live with this situations. It gives a verry restless view on the screen. Thank you for all the help in this case.
I still hope that in next coming versions this all will be back "to normal" like in versions before.
Title: Re: Network
Post by: EK01 on July 27, 2009, 02:32:44 PM
Quote from: sterigia on July 26, 2009, 07:43:12 PM
cheers,
frank
Frank,
Be assured your network connection is not slow. I have the exact same problem which never happened before. Just as well I am still  receiving my free time for this facility. If I was paying for the service which many are probably now doing, I would be looking for some sort of compensation. After all, what is the point in paying for something you are not properly receiving.
Title: Re: Network
Post by: radarspotter10 on July 27, 2009, 02:55:18 PM
hi john.
i am the same ,what i cannot understand is when i downloaded new version it work perfect, now its away with the fairies.
from pat
Title: Re: Network
Post by: sterigia on July 27, 2009, 03:28:37 PM
Quote from: EK01 on July 27, 2009, 02:32:44 PM
cheers,
frank
Frank,
the fact is that in a way we do pay because the info we share is sold to other users.
frank
Title: Re: Network
Post by: Jeremy on July 27, 2009, 03:59:34 PM
Patience chaps. We get extremely good support 18 hours a day and at weekends from Airnav on this forum, way beyond expectations and 'reasonable' service. A couple of days of reduced service occasionally when there are tech problems is not unusual in this industry and I am sure they will sort out the problem soon, be it by a reconfigure of their servers or a replacement. I am sure that they are tearing their hair out with frustration as well as us!
Jeremy.
Title: Re: Network
Post by: AirNav Support on July 27, 2009, 04:22:52 PM
It is online again, We are still working on the issue and apologise for the drop outs.
Title: Re: Network
Post by: John Racars on July 28, 2009, 06:23:54 AM
Quote from: AirNav Support on July 27, 2009, 04:22:52 PMWe are still working on the issue and apologise for the drop outs.
Hi. Support,
Verry good! I know you are working on it. Let us wait patiently for a good solution.
Title: Re: Network
Post by: DVDW on July 28, 2009, 07:05:02 AM
Network is working fine at this moment. I get continuously around 500 flights without any extreme jumping of the network grid.
Dirk.
Title: Re: Network
Post by: Jeremy on July 28, 2009, 08:50:20 PM
Airnav - can we have an update as to what the present situation is? I see only 355 flights on the network but am not sure if this is because it is quiet or not. 2150.
J.
Title: Re: Network
Post by: AirNav Support on July 28, 2009, 08:57:31 PM
If your using the beta version then read our earlier posts. The server is showing about 900 flights at the moment but with your timeout settings that will vary.
Title: Re: Network
Post by: sterigia on August 04, 2009, 01:23:34 PM
sorry to moan again but the network is still showing from 190-500 to zero flights again. before the update i got over 1000 flights regularly
frank
Title: Re: Network
Post by: AirNav Support on August 04, 2009, 02:03:02 PM
Pleas read the message above yours.
Title: Re: Network
Post by: sterigia on August 04, 2009, 03:48:37 PM
is there any setting i can alter to correct this anomaly?
frank
Title: Re: Network
Post by: RodBearden on August 04, 2009, 03:53:44 PM
Frank - I think we have two options - hang on for version 3.02, or go back to an earlier version. I've got a very slow internet connection, and am finding the network nearly unusable, but I'm personally sticking with 3.01 because it has so many good features.
I've lost track of which versions do what, but version 2 worked ok!
Title: Re: Network
Post by: sterigia on August 04, 2009, 04:08:19 PM
i have an adsl 8 mbit/sec in download but it wont work. i think i will go back to version 2 but if the problem is server based it will do no good, i think
thanks for suggestion
frank
Title: Re: Network
Post by: sterigia on August 04, 2009, 06:33:24 PM
update: i have reinstalled version 2 and it gets far more network traffic, about 1000 aircraft, and no outages. i'll just wait until the problems are resolved
frank
