I have the software running on 2 laptop PC's (both XP) and get the same aircraft in the grid window. However, I get all the flights displaying (that should) in the map window on one PC but on the other I get much less and then over time I get none. I have uninstalled and re-installed the software but this does not help.
I am running the 2009 v 2.0 software and not the new Beta (as thye laptop with the problems a Dell Inspirion 6200 will not run ther beta software).
Any ideas?
mark
Not sure what you mean that they won't run the beta software?
one does but one does not as I get a Microsoft failure message saying that anrb.exe has encountered an error in loading.
but that is not may main problem - the problem is aircraft not appearing on the map (or they do for 10 mins or so then they stop displaying yet i can see them in the list). If i unplug USB and plug into other machine they display immediately.
That issue about the beta was in the first beta. A second beta has been released.
We haven't had any similar issues with version 2 that you mention.
what is link for 2nd beta download ? - i will try that one and let you know
I have rebooted macxhine completely and the map display seems to have rectified - will come back if re-occurs?
Quote from: markyeulett on August 15, 2009, 05:35:08 PM
Beta V3.01 is the last release, available here:
http://www.airnavsystems.com/forum/index.php?topic=3141.0
