Hi people,
I did de procedure to upgrade RB firmware.
http://www.airnavsystems.com/download/anrb/anrb13/FirmwareUpdater.exe
Before update it was 1010
After update it is 1012
Could someone inform me if this is correct since I thought that it would be 1013 .
Thanks in advane. Juan
Thats fine, the software version after you upgrade should be 1.3 and the firmware should be 1012.
Infact as long as the software 1.3 works then that means you have the correct firmware as it wll only work with that firmware.
Hope that helps.
Ok, thanks a lot.
So all is fine and working !!!
Thanks also for your quick answer. Juan
