AirNav Radar => AirNav Radar Discussion => Topic started by: dapman on February 27, 2010, 12:57:04 AM
Title: How Accurate is the Info
Post by: dapman on February 27, 2010, 12:57:04 AM
     I was just watching an aircraft making a landing at my local airport EGMC .I live about a mile away,my antenna is 30ft up and as a result i can see the plane moving on the ground.But the last report from the airplane showed it at 450ft and 90knts can anyone explain.I would have expected 0ft and 10knts.Whilst i am posting i used satellite cable to my antenna which is good to 2ghz and easy to route compared to westflex.The fact it is 72 ohm did not cause a problem,the polar diagram goes out to 150 miles.
                                                 Cheers Dave.
Title: Re: How Accurate is the Info
Post by: DaveReid on February 27, 2010, 07:21:04 AM
Quote from: dapman on February 27, 2010, 12:57:04 AMI was just watching an aircraft making a landing at my local airport EGMC .I live about a mile away,my antenna is 30ft up and as a result i can see the plane moving on the ground.But the last report from the airplane showed it at 450ft and 90knts can anyone explain.I would have expected 0ft and 10knts.Whilst i am posting i used satellite cable to my antenna which is good to 2ghz and easy to route compared to westflex.The fact it is 72 ohm did not cause a problem,the polar diagram goes out to 150 miles.
What's the elevation of the airport in question ?
Post by: tarbat on February 27, 2010, 09:01:02 AM
Have you set the correct QNH for EGMC?  Currently 995.  Make sure you use the "Auto Set QNH" facility in SmartView.
Post by: g0seg on February 27, 2010, 12:30:05 PM
Hi Dapman, using 40 odd feet of satellite cable to a copper curlywhirly. We are at around 150 feet here in Yorkshire and using 75 Ohm coax doesn`t appear to make much difference apart from a possibly slightly deformed polar. The attached pic is for 14 days worth of intercept so no problems. As for Southend, used to cycle there from Kings Cross area of London - had a girlfriend at Westcliffe is it? Mind you, it was nearly 60 years ago!!! Bi now and good luck, Roger
Post by: dapman on February 28, 2010, 11:24:58 AM
       Tarbat    Thanks for the info,i will see if it makes a difference.
                                       Cheers Dave.
