AirNav Radar => AirNav Radar Discussion => Topic started by: cool_1 on April 20, 2010, 08:49:07 AM
Title: 3D Interface - When click on aircraft, LHS panel not refreshing...but 2D OK.
Post by: cool_1 on April 20, 2010, 08:49:07 AM
just wondered if anyone else getting this problem, as we've had one or 2 Airnav server problems in the past causing the odd issue.
When using the 3D Interface (v 4.03) - When I double-click on any network aircraft on the RHS Google Map globe, the LHS 'aircraft info panel' is not refreshing.
The 2D Map works OK as normal...ie if you select any aircraft on the RHS map,  the correct airline info Mode S info, Flight ID etc is displayed on the LHS.  (I dont have any aircraft locally due to the Volcanic Ash situation to see if its doing this on network flights only).
I dont recall changing any 3D settings, and I cannot seem to find anything in the menus.  I have also carried out a re-install (without an un-install), which made no difference.
Should I reports as a bug, or is it a known issue ?  any help appreciated.
Maybe the Volcanic Ash is affecting my ability to use Radarbox 3D.... ;-)
regards,
Jon
