Hi all.
In the past week or so, my Radarbox seems to be partially deaf. I live about 25 miles south of KLAX and have many busy airports within range. I typically showed 20Msgs/sec consistently and now I'm lucky to have 4. I've also noticed that aircraft that should be showing position info aren't being recieved at all.
I will say that I did mess with the D009C.dat to get rid of the old log that always pops up and I added the military flags for the US and UK.
I tried to remove the software and reinstall, but I'm still having the same prob.
Mark
Mark,
If you've checked all the obvious things - antenna, antenna connection, antenna location - then I should email support direct at:
[email protected]Have you got an alternative antenna you can try?
