EDIT ROUTE INFO
I want to make changes in my itinerary Sign Manual.
The entry in column or FN FIN781R WZZ160G, I can HLX81M
FN in column about, but the next entries in column NO, ND, NV U.S.
are not possible??
But others, such as flight numbers, or DLH2HT CLX732, Ber715V, AUA73JP
can be no problem in the columns of FN, NE, ND, NV, about CH.
I also Veruchte flight numbers under Text to Find entered since then apply with the flight number is NOT FIND vorhanden.Laesst to
but do not register, even if it vorhanden.Gibt NICT Change Delete an opportunity to IN is possible to completely block numbers. Einzelg Yes
Several but to Delete to select un??.
Please help
To enter details in the NE, ND,NV and CH column you need to select Edit button which opens the box to enter your new details.
